avatar_71GranCoupe
Could use some help.
Started by 71GranCoupe, April 15, 2017, 11:28:32 AM
71GranCoupe
 :soshelp: I am looking at a grill for a 71 Barracuda/Cuda. It is a re-pop and the ends looks like they are distorted. Below is a picture of one of the ends. It looks like the lower curve on the end is not quite right. Take a look and let me know what you think. thanks
cudajunction
Are you thinking right above where the box top edge is?  Looks like a dimple of some sort on this little screen.
71GranCoupe
Quote from: cudajunction on April 15, 2017, 11:46:47 AM
Still new to all this computer stuff and not sure how to draw a circle around the area of concern, but the curve that is seen at the seam of the box is the curve that has me wondering.
@71GranCoupe   Looks like it might be off a bit.   :huh:  Here's a photo of an original 71 grille.
71GranCoupe
Thanks Cody, that is what I was thinking. Away from home makes it tough at times working off memory. I have/had a chance to get a new grill I found, but it looks to be a second. I have a really nice original, and should just use it.
cudajunction
Looks like it might be going back to the seller???
Dang: It looks like once you touch it, it could be all over but the crying.
See if the guy who sold it to you will part with it for a cheap price as a flawed part and then get out your heat gun and with a CAREFUL application of heat, move that dent on out and your "new" grille should be fine. It was probably dropped on it's end, but being basically a big car model part, you should be able to iron that out easily. Sitting it in the car would give you the opportunity to carefully match the desired contours, too.  :cheers:
Definitely damaged, but might be an easy fix if the price is right. :alan2cents:
71GranCoupe
Thanks for all the help on this. I did not buy it, was really considering it, but the curved end(s) created enough concern to ask questions. I have a really nice original that has 2 small cracks between the headlights and will probably go back to plan A. The price is really good but with having to rework it, just makes it questionable.  :cheers:
