70 ralley cluster problems
Started by Chryco, October 18, 2018, 03:53:51 AM
Chryco
Need help. Temp, oil, and gas guage are not functioning. Everything else is good. Any recommendations?
Tommy The Chryco
Cuda Rubber Bumpers and The Better "Shaker Kits"
1-866-893-2547
Car-nutt
Need a little more info, do you have a new wiring harness?
TelisSE440
Jay Bee
A picture is worth a thousand words. If you haven't got a solid state one yet, it's highly recommended to do so. The one in the pic is OEM. P.S. maybe the output wire fell off, but that's very unlikely.
Yes: Voltage limiter is the first thing to check.
Chryco
Its blowing the voltage regulator and its new wiring.
Tommy The Chryco
1-866-893-2547
The Reg is a simple device it should not blow up unless it is connected improperly
Check that your instrument mounting studs aren't grounded out on the pot metal cluster body.
