Need help please!
Started by Spikedog08, July 09, 2023, 10:49:57 AM
Spikedog08
First I'm pretty good at figuring out sh!t but electrical is probably my weak area although I learn pretty fast.  So I am converting to a rallye dash and am at the end of the procedure and this morning I finally put power to the system with hopes all would be good.  First good thing is nothing caught on fire, next the starter did engage when I turned the key.  Couple problems as follows with the first being the biggest issue . .
Convertible top did nothing and it is down.  If I cannot figure this out, may have to go to plan B for the trip to Carlisle.
So first question is about the new rallye dash harness . . The old fuse box used all the spots for fuses but the new one has one empty on the top left?  Why is one not used?  So which fuse is for the convertible top?
Also when I powered the system, the oil pressure gauge went all the way to high
Let's start with these questions and maybe I can get this figured out.  I pulled it all apart and tried the old power top switch and same result  . . No power.
73chalngr
The rallye gauge oil sender may be different than a standard gauge sender .
moparroy
Does the old standard dash even have an oil gauge or does it have a light? LIght would use a switch type sending unit vs a variable for gauge
Mixup7071
Now I'm not positive but I don't think the power top has a fuse, it's wire direct, it could have a circuit breaker
Jay Bee
I don't think the wrong oil sending unit would make the gauge peg, but that's just a guess. I'd be more prone to see if the grey wire is grounding out  somewhere. You know, kind of how we check fuel sending gauges by grounding the blue wire.
Do you have the 30A convertible top circuit breaker (not a fuse) on the fuse block. It should be right beside the horn relay. If it's there check to make sure the connector didn't come loose from the top switch when the switch panel went back in. I've had various switch plugs come off when putting that back in.
Quote from: 73chalngr on July 09, 2023, 10:59:05 AM
They are NOT the same sending unit..  :alan2cents:
Jay Bee
Jay Bee
More info.
Pic 1 back of fuse box: Red & Red w/Black tracer are convertible top circuit breaker wires.
Pic 2 front of fuse box: convertible top circuit breaker beside horn relay.
moparroy
The rallye sending unit pictured is a variable resistor for a gauge. The standard dash is a switch I would say (my '85 Daytona has both). The switch is for an idiot light and yes I believe a switch will peg the gauge as it will switch directly to ground
The convertible top uses a separate harness you would have had to save from your old main dash harness :alan2cents:
Spikedog08
Thanks for the answers so far.  I bought a complete rallye cluster and side panel with the correct Top Lift switch.  I did find the convertible wiring harness and wired it into the new harness like the old one was . .so the missing fuse circuit is not part of the no power situation.  As stated, I will get in there and make sure all stayed connected when installed.  Certainly worked before tearing apart.  And I took the old switch and hooked it up with the same result.  Those pictures are a helpful start . .
Jay Bee
I read on FEBO that the Red & Red w/Black tracer should be oriented as in the picture.
Spikedog08
#12
So double checked and appears to be as stated.  I’m gonna tear the front apart and make sure all is connected securely.  Your circuit breaker has a 130 and mine has 189 on it but certainly looks the same.  Assume that is an inspector number or something . .
Spikedog08
#13
Quote from: Jay Bee on July 09, 2023, 03:00:16 PM
Now that’s interesting . . I may have mixed them up?
70vert
just checked the circuit breaker on my 70 Challenger Vert and it has numbers 389. It is most likely not original, but also does not look new  :dunno:  It does work  :)
