avatar_Mopar94
No rear hazard light
Started by Mopar94, January 20, 2019, 11:31:22 PM
Mopar94
Hello ! I came to tell you, issue solved with a replacement of the turn signal switch ( TW7 available on Rockauto ) I've just changed the knob for the hazard light, to fit with my 70, easy job.
Thanks everyone  :perfect10:
if the flasher is OK it pretty much had to be the switch , Glad you solved it  :bigthumb:
