avatar_Cudamike
No start
Started by Cudamike, April 29, 2017, 10:11:28 AM
test the brown wire with an ohmmeter,make sure it has a good ground , if auto it will ground on the trans safety switch
 :iagree:
Most likely the NSS/CSS stopping you from starting
Cudamike
Cudamike
Pushed,pulled and jiggled all wires that came out of relay and it started. I don't know which one it was.  :notsure:
Have you checked your Clutch Safety Switch?
Cudamike
Car was originally an auto and it doesn't have one.
Have you checked the safety connection at the trans?
Quote from: Cudamike on April 30, 2017, 08:35:25 AM
the brown / second wire / not yellow /has to be grounded somewhere
th yellow wires should have power in the crank position
Cudamike
So if brown wire is not grounded the yellow will have no power?  The green wire is grounded under the bolt that holds the relay to fender.
Sorry for the delay I have been VT my son got a job as a forester.
You are ok the green wire is the ground
Cudamike
#25
Thanks and what does the yellow wire do. I think it might be the problem.
Yellow feeds power from the ign switch which closes the relay & shunts power to the starter
