normal_post in No stop or Turn signals on Right rear in Electrical & Audio Author Topic: No stop or Turn signals on Right rear  (Read 283 times)
Offline cbrown888
  • Trade Count: (0)
  • Leaning Tower of Power
    • Share Post
xx in No stop or Turn signals on Right rear in Electrical & Audio
« on: September 22, 2022, 04:49:22 PM »
Ok this has my head scratching. Have 71 Challenger that I just got done with recleaning up the trunk area because of mice including paint and rewrapping the rear lights wiring harness replacing all rear bulbs and new fuel tank. Tested the rear running lamps all worked fine. Turned on left signal worked fine, turned on right, inop. Hit brakes only the left goes on, hit 4 ways only the left go on not right rear. Right front signal works fine. I replaced the turn signal switch when I restored the car 30 years ago but I am thinking that may have gone bad from lack of use.
Linkback: https://forum.e-bodies.org/electrical-and-audio/11/no-stop-or-turn-signals-on-right-rear/26495/
Offline Chryco Psycho
  • Global Moderator
  • Trade Count: (0)
  • E-Body Wizard
  • index in No stop or Turn signals on Right rear in Electrical & Audio
  • Challenger ... You'll wish you hadn't !!
    • Share Post
Re: No stop or Turn signals on Right rear
« Reply #1 on: September 23, 2022, 01:17:02 AM »
If you are getting no power to the right Rear then the TS switch is the likely culprit .
 Standard TW7 is the correct part & is or was available from Rock auto
1-190417082201 in No stop or Turn signals on Right rear in Electrical & Audio
Offline BIGSHCLUNK
  • Trade Count: (0)
  • Six Pack
    • Share Post
« Reply #2 on: September 23, 2022, 08:05:26 AM »
 :iagree:   had no brake lights on the right... TS was the culprit
Online anlauto
  • Trade Count: (19)
  • E-Body Wizard
  • Life is like a box of chocolates....
    • Share Post
    • www_sm in No stop or Turn signals on Right rear in Electrical & Audio
« Reply #3 on: September 23, 2022, 09:42:26 AM »
For what it is worth....I used Standard TW7 switches for years with no issues....then recently switched to the OER brand because they are cheaper and look better in my opinion...
HOWEVER....I've had a few issues with the OER brand, most of which was the signal lights not wanting to cancel when turning....and more recently, A customer who I finished his car over a year ago, is now telling me there's no brake light on the passenger side :dunno:
Offline 70rag383
  • Trade Count: (0)
  • Small Block
    • Share Post
« Reply #4 on: September 23, 2022, 12:54:23 PM »
I recently had a similar problem where my brake lights stopped working but the turn signals were working. I removed the TS switch and found the contacts between the two components were not making good contact. I made sure the actual turn signal lever was very tight when I remounted the switch and screwed the lever back in. This seem to make the contact points better aligned and it worked!
Offline cbrown888
  • Trade Count: (0)
    • Share Post
clip in No stop or Turn signals on Right rear in Electrical & Audio
« Reply #5 on: September 23, 2022, 07:04:18 PM »
Found it. It was driving me nuts so before I left for work today I checked the connection of the t/s switch and the harness and had power to both sides. When I got home this evening I went to the trunk, pulled the new GE bulbs, that I just installed last week, out of the r/s taillamps and checked the contacts with the test light and both were blinking. Put the GE 1157 bulbs back in and again nothing. Went to the basement and went to my lightbulb cabinet and pulled out a couple of cheap bulbs and put them in and they were working. What a relief of not having to tear the car apart.
On another front while I was refreshing the car I decided to replace the pitted side marker bezels. Everything was fine and went to test the lights and kept blowing fuses. Disconnected the front right still blowing fuses, disconnected the l/f no blown fuse. Pulled the lamp assembly apart, pulled the wire insulation back and found the positive lead just hanging in the socket not attached to anything. Goes to show that you think you are paying more for a quality product and it is just as much junk as the cheaper item.
xx
No Turn signals
Started by Caparco
Last post October 03, 2021, 06:19:23 AM
by Caparco
xx
Fender turn signals
Started by redgum78
Last post January 20, 2019, 08:50:40 AM
by JS29
clip
73 fender turn signals
Started by fireguyfire
Last post March 28, 2020, 05:55:52 AM
by JS29
xx
fender turn signals
Started by pink aar
Last post February 09, 2019, 07:51:40 AM
by Jay Bee
xx
73 challenger turn signals
Started by lcb73
Last post July 10, 2022, 12:03:06 PM
by dodj
