avatar_BigmanjbMOPAR
Tach isn't working
Started by BigmanjbMOPAR, February 27, 2021, 12:48:56 AM
BigmanjbMOPAR
For some reason my tach in my rallye cluster isn't working I tried it with the new msd box and direct to the coil neg. (Dash is partially out still). are they know to go bad or is there something I'm missing?
Having other issues too but haven't tried to troubleshoot them yet.
70 Cuda Project Purple Book
Skdmark
Did you have a good ground to the tach case?
If you have the tach out, you might want to consider upgrading the internals. RT-Eng has 2 kits available.
https://www.rt-eng.com/index.php/RTE_67-74_Tach_kit.html
https://www.rt-eng.com/index.php/67-74_Tach_Board_with_Calibrator_Built_In.html
-Harlan Ellison
:stayinlane:
JP426
I have heard that the factory tach will not work with a MSD box without a separate MSD tach adapter. Apparently it doesn't get the correct signal.
