normal_post in 1970 383 R/T throttle linkage in Engine, Transmission & Rear End Author Topic: 1970 383 R/T throttle linkage  (Read 277 times)
Offline broughj
  • Trade Count: (0)
  • Leaning Tower of Power
  • Credits: 130
    • Share Post
clip in 1970 383 R/T throttle linkage in Engine, Transmission & Rear End
« on: February 14, 2020, 12:22:30 PM »
I must have something assembled wrong with my linkage.  I have a correct 4368 Holley carb and what is supposedly the correct throttle bracket and kickdown linkage.  However, nothing lines up very well.  Anyone have some pictures of how it should all go together?  Thanks,
John
Linkback: https://forum.e-bodies.org/engine-transmission-and-rear-end/4/1970-383-rt-throttle-linkage/14808/
Offline headejm
  • Trade Count: (1)
  • Big Block
  • index in 1970 383 R/T throttle linkage in Engine, Transmission & Rear End
  • Credits: 4370
  • No matter where you go...there you are
    • Share Post
Re: 1970 383 R/T throttle linkage
« Reply #1 on: February 14, 2020, 12:43:31 PM »
 :cheers:
Offline Cuda Cody
  • Administrator
  • Trade Count: (5)
  • E-Body Wizard
  • Credits: 14670
    • Share Post
« Reply #2 on: February 14, 2020, 04:05:32 PM »
@broughj  Does this help?  (Click photos to enlarge)
Offline broughj
  • Trade Count: (0)
  • Credits: 130
    • Share Post
xx in 1970 383 R/T throttle linkage in Engine, Transmission & Rear End
« Reply #3 on: February 15, 2020, 03:41:12 AM »
Thanks for the help. Looks like I do have all the parts assembled correctly. The picture from Cuda Cody looks like the throttle cable and the kick down link line up a good bit better than on mine.  I'm going to play with it a bit more and see if I can get everything to lineup a bit better.
Thanks,
John
Offline Chryco Psycho
  • Global Moderator
  • Trade Count: (0)
  • E-Body Wizard
  • Credits: 26450
  • Challenger ... You'll wish you hadn't !!
    • Share Post
« Reply #4 on: February 15, 2020, 02:52:56 PM »
You should be able to tweak the bracket outward a bit so it is more inline . :alan2cents:
1-190417082201 in 1970 383 R/T throttle linkage in Engine, Transmission & Rear End
Offline broughj
  • Trade Count: (0)
  • Credits: 130
    • Share Post
« Reply #5 on: February 17, 2020, 03:42:48 AM »
It was the throttle bracket.  I found another one in my extra parts and noticed it was made a little bit differently than the one I initially used.  Bolted that one on and things lined up as they should.  Perhaps the bracket I used at first was for a 2BBL or maybe an AVS equipped engine.  After looking at some pictures of the kickdown linkage on other cars, I'm starting to wonder if what I have is correct for my setup.  The parts manual identifies quite a few different part numbers for the rods and bellcranks for various body and engine combos.  I have not been able to find the part numbers or any ID stamped on any of the parts that I have, so without a known original to compare with not sure how to figure out if what I have is correct or not.  I can adjust what I have so that it gets full travel at WOT, so perhaps I should declare it good enough.  Thanks for the help!
Offline anlauto
  • Trade Count: (9)
  • E-Body Wizard
  • Credits: 32160
  • Life is like a box of chocolates....
    • Share Post
    • www_sm in 1970 383 R/T throttle linkage in Engine, Transmission & Rear End
« Reply #6 on: February 17, 2020, 08:16:16 AM »
Yea, trying to "piece together" a set is pretty difficult with all the different versions out there. Most times it's just easier to buy a new set-up. Thankfully it sounds as if you have your set all figured out now :twothumbsup:
Online RUNCHARGER
  • Trade Count: (7)
  • E-Body Wizard
  • Credits: 25330
    • Share Post
« Reply #7 on: February 17, 2020, 08:21:42 AM »
Agreed: Quite a few pieces and no #'s stamped on them makes it tough. One of the reasons I hate basket cases.
xx
1970 340 Throttle Cable
Started by plymouthbelvy
Last post December 22, 2017, 04:46:08 PM
by plymouthbelvy
xx
1970 Challenger RT 440 Throttle Cable
Started by kent_goins
Last post April 07, 2019, 04:44:22 PM
by RUNCHARGER
xx
1970 340 Cuda Throttle Cable
Started by VCODE
Last post August 18, 2017, 01:39:04 PM
by Cuda Cody
moved
MOVED: 1970 340 Throttle Cable
Started by Spikedog08
Last post December 22, 2017, 10:37:54 AM
by Spikedog08
clip
1970 340 throttle return spring color?
Started by benlavigne
Last post Today at 05:33:11 PM
by benlavigne
