340 .030 over, what to look for?
Started by Cuda416, December 22, 2019, 07:15:37 AM
Cuda416
I may be picking up a 340 block that is believed to have been border .030. Other than a good visual of the cylinders, cam and crank bearing surfaces, what should I look for? Also available is a steel crank and factory rods.
U.S.M.C. SFMF
70 Barracuda Vert
69 Dart Vert
65 Valiant
At .030 you want it to be usable so no ridge, no gouges in the bores etc. If he wants more than a few hundred for it I would make the sale subject to a sonic and magnaflux test.
headejm
I would want critical measurements taken such as deck flatness, bore diameter, cam bore, and crank bore with the caps torqued. Also, I would want to check for cracks by having the block Magnafluxed. You definitely don't want to find a crack after you build up the engine.
Basically, I'd take it to a reputable engine machine shop and have it checked out. They will know what and how to check it out. Good luck!  :cheers:
Cuda416
U.S.M.C. SFMF
70 Barracuda Vert
69 Dart Vert
65 Valiant
