340 rockerarms
Started by Qda71, April 15, 2024, 01:22:14 PM
Qda71
How much tolerance are accepted between shaft and rockerarms? I have slight ticking and i checked some of my rocker arms feels loose on the shaft i think that what create the noise .
Just Love all american iron ... but i have a soft spot for ebody mopars.
More questions than answers , where is the play , side to side or pushing down on the pushrod , I assume it is a hydraulic cam not solid using stock rockers or no ? if the pushrods will depress the lifters are collapsed & not holding pressure.  How long has the engine sat ' cold or still hot when the rockers feel loose ?
 The rockers should be loose on the shaft but under load between the pushrod & valve tip .
Qda71
Stock engine
Hydraulic cam
Stock rockerarms
Engine cold
Tick when warm
Rockerarm play all directions.
Hydraulic Lifters are 500 miles old been told from previous owner .
Lifters could be a bad set , or have deeper cup height causing the pushrods to be too short
