avatar_Daveh
340 Water Pump Bolt Dimension
Started by Daveh, August 19, 2020, 04:13:51 PM
Daveh
Hey Guys,
Can someone please confirm the dimensions of the water pump bolt that I circled in the pic?  Want to make sure I have the correct length.
I have a 5" and 5-1/2".  Both fit but would one be better than the other?
Headjam
I would use the shorter one IF you have a minimum of 4 full threads of engagement
Daveh
It grabs just fine I will use the shorter one.  Thanks Neil.
