Basic Clutch Info
Started by Cuda Cody, December 26, 2016, 07:11:02 PM
Neil has asked me to help move some of his knowledge to this site and this is a test to see how best to do it....
Lets take a look a clutches
there are a 3 of variables from early 60 s to 69 there were 2 set ups for big blocks, small blocks used the 130 tooth
set up the 130 tooth flywheel using a 10.5" clutch for light duty applicatins from slant 6 -383 &
the 143 tooth flywheel used in 440 & Hemi applications with the 11" clutch
in 70 they started using the 10.95 " clutch [commonly] refered to as the 11"] with a
scalloped pressure plate on the 130 tooth flywheel
Even though both clutches are refer to as 11" Nothing will interchange Due to the flywheel
diameter & bolt patterns , the 143 tooth uses a cast iron belhousing & repositions the
starter away from the crank , the 130 tooth flywheel uses an alum belhousing with the starter
closer to the crank , there is also a Thrid Belhousing used in the mid 60 Hemi applications
that uses a direct drive starter instead of the usual gear reduction starter
The Truck Belhousings for the 833 tranny with side shifter  will work in cars as well but
the truck bells for the A435 tranny with top shift will not work in car applications &
the slant 6 bell is a totally unique again & the car & truck bells are different but can
be made to work , the belhousing must also be matched to the front retainer size on the
833 tranny , the 23 spline had either 4.35 " or 4.80 " diameter , the 18 spline only used
the 4.80 , & the OD 833 used the 5.125 dia
  With the flywheels there are a lot of things to think about the slant ^ uses a differnt
bolt pattern from the V8 & also uses a 10" clutch
the V8 flywheels all use the same bolt pattern except the Hemi with 8 bolt crank flange &
use 7/16" fine threads bolt into the crank flange
as mentioned the 143 tooth flywheel uses a larger pressure plate with a wider bolt circle
the 130 tooth flywheel uses a pressure plate with the bolts so tight to the plate that
the plate is actually notched for clearance & it uses a special bolt like a header bolt
but with a shoulder to mount the pressure plate ALL clutches must be mounted using Special
3/8" shouldered bolts that recess into the flywheel with a 1/4" shoulder , using a regular
even grade 8 bolt can cause failure as the pressure plate can move against the threads &
hear the bolts off , generally this will make a mess , Usually a 10.95 pressure plate will
be supplied with new bolts when purchased. the other thing to keep in mind with flywheels
is balancing , the 400 , 360 , 440+6 were all externally balanced so you need to be sure
you have the correct flywheel for the engine, For racing I highly recommend going to a
Blastsheild & a
Steel SFI spec flywheel over the factory cast flywheel mopar has both 6 bolt 130 tooth
P4529142  & the 8 bolt 130 tooth P4529143 available , I believe McLeod also has the 143
tooth steel flywheels available , the 360 6 bolt flywheel is also available P4529110 for
the pre-magnum engines & P5249842 for the Crate & Magnum engine , for the 440+6 & 400
you will need to locate a used flywheel or have the engine balanced with the flywheel
while building the engine
There are also 3+ styles of clutch ,
1] the Diaphragm - This is generally used by GM & more recently the Cummins , it has the
lightest pedal pressure & is used in low HP applications for the most part [except Cummins]
they have 18 fingers where the release brg pushes on it clutch , there are no springs just
a single plate stamped into a cone shape , Dynapack kits & Centerforce are selling these
virtually exclusively now & I am not a fan of them  I have seen may of them fail or slip
the only reason they survive in the Cummins is because the clutch is generally engaged at
idle &  it has a massive 14" disc with huge surface area , start abusing the cummns at the
track or towing & the will fail rapidly, also at high rpm the clutch may stay released &
not return to clamp the disc , I hope you have a rev limiter !!!
2] the 3 finger Borg & Beck style , this is what was used from the factory they have 9-12
springs & these can be changed with lighter or heavier springs to adjust clamping pressures
but have higher pedal pressure & are available new from Mopar P4529141 for the 10.95 , I
recoomend using these in virtually any application as the cost is similar & the extra
surface area will help life & load carrying ability.These also have the advantage of using
rollers inside them to increase plate pressure with Rpm , if you shake the PP & it rattles
it has the centrifical rollers in the plate
3] The best style is the Borg & Beck Long style , the only source for this is McLeod , it
is a hybrid being & B&B stytle but using the long style levers mostly foundin  ford
applications , it is also designed with 9 - 12 coil springs but the release levers are
longer so the pedal pressure is reduced & the clutch releases faster too. The release arms
also have provision to add extra weight to increase centrifical loading with RPM , these
are more expensive but well worth it in the right applications
4]Last there are multi disc clutches , by using 2 discs & a separator plate the surface area
is doubled so without increasing pressure more power can be transmitted through the clutch
these systems are not cheap at around $1000 but in talking with clutch manufacturers some of
the engine being built recently are exceeding the ratings of any single disc clutch available
There are also a number of choices for clutch discs I won`t even begin to guess how many
types of linings are available for them , but basically there are the fiber discs at the
bottom , next the metal imprgnated which will withstand more heat , Kevlar [looks like
cardboard !!], Ceramic , & the feramic [Velvet touch ] which is far from it . I
recoomend using at least the metal imprgnated discs , the feramic are truly violent , on or
off
In My duster with traction I ate 2 discs in under 500 miles & installed a feramic , it
lived 8 years Racing a street driving & pulled the front wheels with ease , when I installed
it it was bronze/ gold color , when I removed it it was B5 Blue from heat from slippage but
was not worn at all it hadn`t even made full contact on the pucks on the disc
Next we need to consider the release brg , there are only 2 , due to the different diameter
of the input shaft between 23 & 18 spline trannys you need to matching brg
the SKF XXXXXX is the 23 spline brg , it is easy to get & only $35 or so
the P4529064 is thew 18 Spline Hemi brg this is obsolete from everyone except Mopar & is
over $100, SKF does have the brg without the iron sleeve though #N1181, you will need to press
the brg on & off
There are 3 clutch forks available , A body A engine P 4529451
B body A engine P4529452
B body B engine P4529453
all these use the flat angled pivot , the truck belhousings use a ball pivot & different fork so
keep them together
Clutch adjuster rods are available from Mopar as well
A & a P4529448. B & A P4529449 , & B & B P4529450 but they are expensive
also available is offset dowels to center the belhousing so the tranny is in line with the crank
part # P4120383 , if using a blastsheild these are a must
Pilot bushing should be checked & at least greased while it is apart
Part # 53298 from mopar , it is so old it has a 5 digit part # !!or part # PB286 from Pioneer
the alternative is the Dakota roller brg Part # 53009180AB from Mopar it fits into the torque
converter support in the rear of the crank
As a side note I do not know of any repro Steel covers for the bottom of the belhousings , the
Truck wrecing yard ones will work for small blocks
Wow, that's a lot of info.  Is there a way to space it out or group it so its easier to read?
It was copied and pasted prior to us bringing it over for Neil.  So I will have to go through it and remove the extra spaces.  It needs to be done so it reads right.   :yes:
Ok so am a good mech but not so much a good writer sorry !
The steel inspection covers for the "10.5" BB bellhousings are available in repro now and are of good quality.
SteveG
Nothing to do with E bodies but interesting is the cast iron bell housing used in the D and W series trucks for 61 to 68. They had a bell housing that would accept the 318 poly, LA small block, slant 6, and 251 flat head 6. On the backside you could put on a 3 speed side shift, 435, or 420 four speed. Don't know if a 833 would bolt in or not. Big blocks had a different bell housing.
Bluemonster71RT
Great info! I went through 3 wrong setups because they kept sending wrong parts or the description was wrong for what they offered. I have a 10.95 clutch on my 383. After many issues I went with a 10.5 disk just to get driving. That was a mistake. It slips and cant launch the car correctly among other issues. I should get a new flywheel PP and disk. Worse than the money to get the new stuff is pulling that heavy hunk of iron out of a scatter shield and then the shield on my back. Man that sucks!
I hate doing things twice too.   :Thud:  But as much as it sucks, if you plan to have the car for as long as I think you will I would say you;ll want it to work right.  @Chryco Psycho  is a good resource for info when it comes to clutches.  @1 Wild R/T knows a lot too.  Maybe one of them has some thoughts on this?
Quote from: Bluemonster71RT on June 03, 2017, 07:07:39 PM
Sounds to me like he already knows what he needs, problem is finding it using a typical parts source... Which is why when dealing with Mopar 4 gear stuff stepping up & dealing with either Jamie Passion or Brewers is probably the best option....
I f you have the 130 tooth flywheel which you should with a 10.5" setup you do not need a new flywheel just have it resurfaced, I would get a 10.95" 3 finger Borg & Beck or better yet a Borg & Beck /Long  pressure plate with a new disc , McLeod is the only company making the B&B/Long  tell them how muchHP youhave & they will supply the right pressure & disc
cam440
yeah the McLeod borg and beck are a great clutch I run one in my cuda got all my rebuild kit and clutch from brewers
Plum_crazy_T/A
If you replace the flywheel and don't have the balancing info. how much of a problem could there be?
Jim AAR
The flywheel should already be balanced if it's new. If it's an old one, just have it resurfaced and it should be balanced again as it's just resurfaced like a disc brake rotor.
It would depend if the rotating asy was balanced when the engine was built , most engines are balanced internally so the flywheel has zero effect , but not all .
With lighter rods & pistons used weight can often be removed from the crankshaft but the engine should still be internally balanced not relying on the flywheel .
6 pack & cast crank engines always used specifically balanced flywheels from the factory .
Yes: Whenever I've had an engine balanced the last thing they have done is bolt on the flywheel to the balanced crank and checked it. I also had a problem with a 340 flywheel once on a built car and the engine shop bolted it to a crankshaft they had balanced for another engine and balanced my flywheel on it. It was smooth as silk afterwards.
