Can it be done?
Started by dodj, March 09, 2019, 09:48:21 AM
Going to change to a QA1 K member (probably next winter), Ive seen smaller engined cars with the engine held up with a bar across the inner fenders while the engine support was changed. Think I could do that with a 440?  :thinking:
torredcuda
Should be no problem, just spread the load, the shock towers are pretty strong.
Jeff   `72 Barracuda 340/4spd
Northeast Mighty Mopar Club
mopar jack
Harbor freight sells an engine support bar, $75
mopar jack
I bought one to support and lift my engine to install a milodon oil pan.
 :worship:
Thanks everybody.
I think I'll start soaking the k-member bolts with penetrating oil this summer.
Or you could just go Redneck like I did. :rofl:
It just sat on the frame rails and used some 1/2" all thread.
ALSO... Be sure to remove WP fan if you have a rad shroud.
Nice! @YellowThumper   :drinkingbud:
Those 1/4" bolts attaching the chain?...lol
Actually, cheap, and effective. And you don't end up with a likely 'one time use' tool around the garage.
Quote from: dodj on March 12, 2019, 07:47:36 AM
4x4 for legs was overkill but it was fence post scraping had.
1/2-13 all thread.
Connection was just a metal strap with holes drilled.
Bolts were either 5/16 or 3/8. No not 1/4...
I just had an issue with loading the tops of fender structure. I know it is done and "should" be fine. Frame was in my eyes a better choice.
Oldschool and it worked
:clapping:
