Correct breather for a 440-6
Started by Ric, March 03, 2018, 02:31:16 PM
Ric
 :help: What is the correct breather for a 71 440-6 cuda with a shaker..thanks
ply64post
 :unitedstates:
Check this site out , all kinds of air filters and cleaners identified.
                             Jeff
       http://www.nicksgarage.com/aircleaner.htm
Ric
alot of good info, but still didn't answer it.. saw one for 2-fours..
6bblgt
are you looking for what air cleaner components or a valve cover breather  :dunno:
the valve cover breather is the same regardless of engine/SHAKER & is 3-nipple for all '71 'cuda engines
Ric
figured it out, yes valve cover breather , and yes now I know its  a 3 nipple, but where do all the lines go.....
Yes: 71 means 3 nipple valve cover breather.
6bblgt
smallest - vapor return line that's bolted to the inner fender
middle - fuel bowl of center carb
largest - usually goes to the air cleaner, on a SHAKER it's on the adapter ring
They should be like this... (Thanks to @ScottSmith_Harms for the photo)
Jim AAR
Here's a pic of a Big Block 6 Pak Shaker Base Plate from:
It's about midway down the page.
ksierens
What about for a 1970 440 sixpack?  My center carb does have a vent tube, but should there be 2 or 3 nipples? The vapor return line on my car comes from the vapor separator by the fuel pump.
1970 Challenger R/T 440 Six Pack 4 Speed Dana 3.54
Quote from: ksierens on December 26, 2018, 06:17:39 AM
Your 1970 440+6 will have a one nipple breather connected to the air cleaner...that's all. :alan2cents:
ksierens
Alan, so should I just plug off the vent tube on the center carb?
Sent from my SAMSUNG-SM-G930A using Tapatalk
You have the wrong center carb, I would just leave it open or get a two nipple breather cap like used on an AAR or TA  and put a hose running to the carb. I don't think I would just "plug" the vent  :thinking:
