avatar_usraptor
Dana 60 gear ratio selection question
Started by usraptor, May 20, 2019, 07:17:22 PM
Quote from: RUNCHARGER on May 20, 2019, 07:28:52 PM
How tall are the rear tires? Generally 3.23's are a lot nicer on the freeway than 3.54's are.
Runcharger, I'm running BF Goodrich TA radial 275/60 R15 on the rear.  They spec out at 28" diameter.
 From Dr. Diff's website: https://www.doctordiff.com/dana-60-ring-and-pinion.html
DoctorDiff Drivetrain Components
Home/Drivetrain/Dana 60/Dana 60 Ring and Pinion 16 of 29
Save  Share
$185.00
Gear Ratio:
3.23 DoctorDiff Gear (3 series carrier) (+$15.00)
3.54 Motive Gear (3 series carrier)
3.54 OEM Spicer (3 series carrier) (+$100.00)
3.73 Motive Gear (3 series carrier)
3.73 OEM Spicer (3 series carrier) (+$100.00)
4.10 Motive Gear (3 series carrier)
4.10 OEM Spicer (3 series carrier) (+$100.00)
4.10 Richmond Gear (THIN conversion fits 5 series carrier) (+$40.00)
4.30 Hoosier Gear (3 series carrier)
4.56 Motive Gear (THICK conversion fits 3 series carrier) (+$10.00)
4.56 Motive Gear (5 series carrier)
4.88 Motive Gear (5 series carrier)
Please, select one
Okay between all your suggestions and communicating with Cass at Dr Diff I decided to go with the 3:23 gear set.  In the process of ordering gears, bearings, shims, gaskets, etc.  Anyway, he does not carry speedo gears.  Where can I buy a new speedo gears to match the new 3:23 gears?
BTW, thanks for all the input?   :bravo:  As always, it's very much appreciated.
Quote from: usraptor on May 23, 2019, 11:05:03 AM
First figure out what one you need, maybe someone on here will have what you need lying around?
Spikedog08
Thanks Brad, hadn't thought about the speedo gear . . . If Roseville doesn't have them, I would check with Mancini Racing.  I too am ordering the 3.23!   Excited!
:banana:
:banana:
:banana:
:banana:
:banana:
I have a green 34 tooth speedo gear if anyone needs?
