avatar_cuda hunter
Dana 60 identification
Started by cuda hunter, June 13, 2020, 10:13:47 PM
6bblgt
 :iagree: without it being rebuilt ~$2K is the max. I'd consider  I think for less than $3K you could have all new
the springs have value if not all pitted - they are axle package/440/HEMI pieces (should be 3400024/3400024) & the bottom leaf has a part number / vendor code / date code
I sold these to the same guy that got the green plug  :takemymoney:
6bblgt
are the backing plates 10" or 11"?
cuda hunter
I didn't measure them but I believe they are 10".
The reason I think that is right next to this dana is a supposed 78 fury rear end that has 11" brakes and I can buy that rear for the brake parts to install on the dana.
Here are the pics of that rear end.   Opinions?
cuda hunter
A better pic of the plastic unobtainium.
10 " drums were used on the rear with front disc , I am assuming you will run front disc ?
6bblgt
 :iagree: for 1970 - part way thru 1971 they went with 11" rear drums on 4.10 DANA60 (which all had power disc brakes 1970-'71)
cuda hunter
Well, I'm going to try to mimic the original car as much as possible.  That's why I would change the 410 rear for a correct 354 dana if I find one.   There is not a code for front disc's on the fender tag so I don't think it had disk's.
6bblgt
correct, manual drum brakes - 11" all 4 corners
cuda hunter
Does the dana appear to have 11" brakes?
What size do the brakes look like on that fury rear end?  They appear larger to me.
The 10" are harder to find (if I recall) and bring more money.
cuda hunter
looks like I'm gonna be paying 1800 for this set up.
Not bad since I only have to drive an hour into the mountains to get it.
The Fury brakes are 11 inch. I think $1800 is a good deal, the snubber is there, ratio tags etc. Usually you need to buy that stuff extra.
cuda hunter
Thanks for all the info and opinions about this unit.  I definitely needed them.
