avatar_Wayne
Griffin direct fit radiator and stock shroud?
Started by Wayne, December 22, 2019, 10:30:31 AM
Wayne
I bought a Griffin direct fit 22" radiator for my Cuda and it fits in the car great. The problem I am having is the stock shroud 2998328 doesn't line up.  I'm was under the impression this radiator didn't use the fan shroud brackets...but maybe I'm wrong. I don't have them to check.
Then I started looking at the dimensions for a stock shroud which I found on the Mancini page and they aren't matching up with my shroud.
Has anyone mounted a stock shroud with one of their radiators?
I plan to call Griffin tomorrow and check with them but something just seemed off.
Thanks!
1970 Cuda 383 4spd red on red
cudabob496
#1
my experience is that you line it up as best you can. I bought some of that
1/4 inch by 3/4 inch by 48 inch aluminum at home depot and made little
brackets to mount the shroud against my Howe aluminum radiator.
Wayne
I just thought it was odd it didn't bolt right up and thought there might be a shroud that did fit.  Griffin was helpful but nothing they could really do.  Just going to make some adapters
