hot_post in Installing fuel pump in Engine, Transmission & Rear End Author Topic: Installing fuel pump  (Read 680 times)
Offline nsmall
  • Trade Count: (0)
  • Big Block
  • index in Installing fuel pump in Engine, Transmission & Rear End
  • Credits: 3620
    • Share Post
clip in Installing fuel pump in Engine, Transmission & Rear End
« on: September 12, 2017, 11:27:26 PM »
Yes I'm really asking this.
So when it comes to installing this fuel pump I'm assuming I just go ahead and keep cranking on the bolts and it will work its way in there as it doesn't fit flush.
Also when it comes to the gasket I'm assuming a little goop on both sides is a good idea?
Linkback: https://forum.e-bodies.org/engine-transmission-and-rear-end/4/installing-fuel-pump/3551/
Obviously a rookie.
This restoration is taking an E-bodies.org village.  Thanks!!!
Online Katfish
  • Trade Count: (0)
  • Small Block
  • Credits: 1620
    • Share Post
xx in Installing fuel pump in Engine, Transmission & Rear End
Re: Installing fuel pump
« Reply #1 on: September 13, 2017, 03:34:52 AM »
I think it should sit a little more flush.
Maybe turn the engine over a little and retry.
The pump arm rides directly against the cam on a SB.
Offline anlauto
  • Trade Count: (4)
  • Mighty 426 Hemi
  • Credits: 11320
  • Life is like a box of chocolates....
    • Share Post
    • www_sm in Installing fuel pump in Engine, Transmission & Rear End
« Reply #2 on: September 13, 2017, 04:08:14 AM »
If you tightened it the way it is you'll only activate the pump arm.....no harm done. :alan2cents:
Offline Burdar
  • Trade Count: (0)
  • Big Block
  • Credits: 5160
    • Share Post
« Reply #3 on: September 13, 2017, 07:48:01 AM »
There is a lot of force on that pump arm.  It won't sit flush until the bolts are tight.
Offline Cuda Cody
  • Administrator
  • Trade Count: (3)
  • Mighty 426 Hemi
  • Credits: 4660
    • Share Post
« Reply #4 on: September 13, 2017, 08:12:56 AM »
 :iagree:  Yup, just tighten it until it's flush.  I put a little cam break-in lube on the contact part of the arm too.  Might not be needed, but it doesn't hurt to have a little extra protection on the first start up.  But I think your cam is already broke in so you are probably fine without it if you already installed the pump.
Offline CudaMoparRay
  • Trade Count: (5)
  • Big Block
  • Credits: 310
    • Share Post
« Reply #5 on: September 13, 2017, 03:54:48 PM »
Learn something new every day. I never would have thought to continue tightening it as it seems counter intuitive. Great info to know, thanks guys
Offline HP_Cuda
  • Roast em if ya got em
  • Trade Count: (0)
  • Six Pack
  • Credits: 6820
  • Keep the rubber side down
    • Share Post
« Reply #6 on: September 13, 2017, 04:16:06 PM »
Since it's not flush make sure you are not cross threading before torquing them down.
Online Roadman
  • Trade Count: (0)
  • Six Pack
  • Credits: 1930
    • Share Post
« Reply #7 on: September 13, 2017, 05:36:03 PM »
                        :iagree:  You can turn the motor to the point where you are on the low point of the cam lobe, but will still have pressure on the spring in the pump. Start bolts straight .    :rebelflag"
Offline RUNCHARGER
  • Trade Count: (3)
  • Six Pack
  • Credits: 5510
    • Share Post
« Reply #8 on: September 13, 2017, 05:38:43 PM »
Keep tightening and I use gasket sealer on both sides of the gasket at that spot.
Offline nsmall
  • Trade Count: (0)
  • Big Block
  • Credits: 3620
    • Share Post
« Reply #9 on: September 13, 2017, 05:57:46 PM »
Thanks everyone. Followed your directions...worked great. My car has been painted.  I'm 95% done restoring the parts.  Here are two teaser photos...
Offline RUNCHARGER
  • Trade Count: (3)
  • Six Pack
  • Credits: 5510
    • Share Post
« Reply #10 on: September 13, 2017, 07:12:13 PM »
Oh I like that.
Offline 303 Mopar
  • Frazz
  • Trade Count: (0)
  • Six Pack
  • Credits: 4290
  • '70 Cuda - '68 Charger - '69 Sport Sat Vert
    • Share Post
« Reply #11 on: September 14, 2017, 12:41:45 PM »
proxy in Installing fuel pump in Engine, Transmission & Rear End
Online JS29
  • Trade Count: (0)
  • Big Block
  • Credits: 5710
    • Share Post
« Reply #12 on: September 14, 2017, 01:22:20 PM »
A crossed thread is A sure thread!!!!!!   :barf:
Offline Cuda Cody
  • Administrator
  • Trade Count: (3)
  • Mighty 426 Hemi
  • Credits: 4660
    • Share Post
« Reply #13 on: September 14, 2017, 01:26:49 PM »
That color looks GOOD!!!!!   :1place:
Offline HP_Cuda
  • Trade Count: (0)
  • Six Pack
  • Credits: 6820
    • Share Post
« Reply #14 on: September 14, 2017, 01:28:38 PM »
LOL 303
If you are going to do it don't do it half assed.
xx
6 pack fuel pump?
Started by truckinman466
Last post July 29, 2017, 05:09:12 PM
by Chryco Psycho
xx
Fuel pump Question
Started by bentpshrods
Last post February 22, 2018, 12:32:22 PM
by Shane Kelley
xx
Fuel Pump to Carb Lines 1970 383
Started by erik70rt
Last post April 19, 2017, 09:17:14 AM
by anlauto
xx
Fuel pump relay circuit breaker question
Started by Cudakiller70
Last post May 18, 2017, 02:16:32 PM
by lulurocks(Ken)
xx
Wiring elec fuel pump questions, relay location? oil pressure and or inertia?
Last post May 04, 2017, 08:40:46 PM
by 1 Wild R/T
