LA motor - Snapped off trans alignment dowels
Started by 72 Challenger, January 08, 2018, 07:31:51 AM
The first picture better be the passenger side with the oil filter mount there or you have a very unusual block  !!
72 Challenger
Lol nothing gets by the experts!
Swap the passenger and driver. first pic  is pass second Is driver.
Someday I will have a J0b.
' IF" one had access to a boring mill, I would first put on the transmission square it all up then indicate the holes and dowel pins to make a drawing of the bolt pattern and dowel pin position and crank center, Then drill and ream for 3-4 new pins between the bolt holes. Then put on the engine square it up then indicate the crank and then transfer, drill/ream the dowel holes I just did on the transmission.
But that is in a perfect world , with access to the right equipment.
Block didn't come from Koffel's did it?
See if anyone gets that reference..... :rofl:
Yes, we're "laughing" without gas.
That one dowel hole looks like it will hold a dowel, that will help when checking the runout.
I got thinking if you can just get the housing square on the block and hold it there, you could grind a few square surfaces in the housing and then drill right through into the block to sink a few small dowels?
