avatar_garrett007
six pack carbs 4791 vs 4792 difference?
Started by garrett007, November 13, 2018, 05:43:40 AM
garrett007
What is the difference between the 340 six pack center carbs 4791 (M/T) vs the 4792 (A/t)?  Is linkage? accelerator pump cam?
Thanks,
Garrett
70' Challenger - running
It could be a bleed too. The wrong one will work just fine though.
ScottSmith_Harms
I get this question a lot, mostly from those wondering if the opposite will work on thier cars ok. Short answer is yes, no problem at all, same linkage, same #31 acc nozzle, same 41R-218 cam, and most everything else. Jetting for 4791 is #62, 4792 is #61. So nearly the same.
garrett007
Thanks for the fast reply.  That is what I was looking for .     :ohyeah:
