Suggestions for a radiator for a 340 Plymouth Cuda in $250 to $375 range
Started by soccernut43, November 20, 2020, 05:50:29 AM
soccernut43
Looking for suggestions for an efficient radiator for a 1970 340 Plymouth Cuda.  Not looking for a reproduction, just thoughts on a good radiator for my project. This group always has great ideas and recommendations.  Thanks!
soccernut43
Here are some choices I found at Summit.
73_Cuda_4_Me
I just put this in my Cuda this summer, and other than some slight filing of mounting holes, it works above my expectations.... this one is for an automatic, fyi
https://www.summitracing.com/parts/rad-mop752a
BS23H3B
soccernut43
Thanks!  I liked how they actually asked for the VIN letter in the Application part on Summit.
I would suggest making sure they will accept a factory fan shroud.
soccernut43
Good point.  But I'm not using the factory clutch fan and the shroud while nice if it fits isn't a game breaker if I don't use it.  But again, fantastic point.
soccernut43
It says in the description from Summit that the radiator is for a big block?  Just curious.  Thanks.
73_Cuda_4_Me
DO NOT USE THE 751... the radiator ports do not match!!! (Don't ask me how I know...)
the 752 is for big blocks AND the 340... it's buried in the Cold Case literature for it... mine installed with very little trouble, and ports were top driver's side inlet, and bottom passenger side outlet, with Automatic Transmission ports center bottom...
BS23H3B
soccernut43
Thank you, thank you, thank you.  I won't ask and I don't want to find out.  The 752 it is.  I'm not sure why I feel so relieved but I do lol.
73_Cuda_4_Me
As long as your input and output ports are as I stated, and you have an automatic, it's the one...
They have a similar one (without the A) for manual tranny...
:ohyeah:
BS23H3B
soccernut43
challengermaniac
This was very helpful as I needed the same information!  Thanks everyone!
1970 Challenger Convertible EB5
73_Cuda_4_Me
BS23H3B
soccernut43
Sorry. The motors on a test stand.  An automatic bolts up to it.
