avatar_gaddied
Valvoline Max life tranny fluid?
Started by gaddied, July 29, 2017, 08:22:52 AM
gaddied
So has any one used Valvoline Max Life multi vehicle transmission fluid P/N 773775 for a 70-74 Cuda 727 ??
Just like to know if it is worth trying.
I have not.  But normally you are okay sticking with good name brands.  Valvoline has a good reputation.  Myself, I prefer Mobil 1 synthetic fluids.
gaddied
On a new build I will often use F type
Synthetics are good too & a must for all Newer Mopar transmissions ATF+4  , Mopar / Mobil / Amsoil etc
Castrol is more common than Valvoline in Canada typically
F type offers more friction so clutches & bands have more bite / grip , Similar to B&M Trick Shift fluid
Any shift kit I have seen rec emends type F fluid, especially if you want firmer shifts.  :alan2cents:
gaddied
So, Back to me .
What would be the some suggestions for transmission fluid to use??
Any input would be great.
