avatar_usraptor
What is this bracket for
Started by usraptor, October 03, 2022, 08:01:30 AM
I was wiping down my Dana 60 rear end when I noticed this bracket/mount on the top of passenger side axle tube.  It appears that something is supposed to be bolted to it, as there is a nut welded to the bottom of the mount,  but I have no idea what.  :dunno:  Can any of your enlighten me what the purpose of this mount is and what, if anything, is supposed to be connected to it?  Thanks in advance. P.S. I don't know why two of the pics posted sideways as they're correct in my photo file?
Is the Dana original to the car?  Is there a provision for a pinion snubber?  If it's a truck Dana, they don't have pinion snubbers.  If it's not original to the car, it may have something to do with its original application.
#2
You bolt through the clamp that holds the E-brake cable into it. On a 70 that is, 71 used a different e-brake cable setup.
Thanks Runcharger.  Next time I have it in the air, I'll have to check the routing of my E-brake cable.  Maybe I ended up with a 71 E-brake cable??   :dunno:  Burdar, to answer your questions, yes the dana 60 is original to the car. The pinion snubber is at the front of the Dana housing where the driveshaft attaches.
