avatar_blown motor
What transmission pan gasket
Started by blown motor, February 08, 2022, 07:25:34 AM
I have to replace the transmission pan gasket on a 727. What should I use? Cork, rubber, silicone?
73_Cuda_4_Me
I replaced the pan gasket in my 727 with a reusable silicone/steel core unit available right at Ma Mopar... don't have the number for it, but I believe the number was given in a thread either on here somewhere or over at cc.com... was around 35 bucks, but it sure sealed mine up...
Here... https://forum.e-bodies.org/engine-transmission-and-rear-end/4/difficulty-of-resolving-this-transmission-leak/7664/msg107427#msg107427
BS23H3B
Murray, that $35.00usd or $44.50 Canadian before tax or shipping would buy you a nice big tube of "The Right Stuff" which would not only do the job, but have some left over for future sealing chores. Just sayin'  :cheers:
The silicone gasket 9s also reusable and has a metal insert so you don't overtighten it like so many do.
I also believe the factory recommended torque for the pan gasket is 150 in lbs.
MOPAR MITCH
Regardless whatever gasket you use, the most important factor is the flatness of the mating surfaces (especially a stamped steel-type factory pan), along with the bolt holes and bolts having cleaned threading for proper equal clamp load.
An out-of-flat and/or dimpled bolt hole common with stamped steel trans pans would need to be repaired, replaced or else, use of a very forgiving gasket upon being compressed.
Personally, I favor the Fel-Pro rubber coated dense fiber trans pan gaskets -- very resilient to the constant wall of trans fluid, and can be reused (at your discretion).
Forget about plain cork-rubber gaskets -- they will just saturate and eventually leak fluid.
Silicone gaskets with the center metal/steel core are great, but they are not much forgiving to out-of-flat pans or distorted bolt holes.... better to use a nice new and flat cast aluminum pan with those gaskets.
I'm a former gasket applications engineer with a major company.
