veryhot_post in Exhaust Install Problems - updated - with Video! in Exhaust Author Topic: Exhaust Install Problems - updated - with Video!  (Read 2316 times)
Offline Cudajason
  • Trade Count: (1)
  • Big Block
  • index in Exhaust Install Problems - updated - with Video! in Exhaust
  • Credits: 1010
  • Hey....
    • Share Post
clip in Exhaust Install Problems - updated - with Video! in Exhaust
« on: April 14, 2018, 09:01:28 AM »
 :wave: :wave: :wave:
OK...Something is not right here...and I think its user error and could use some help.
As you can see...sort of... the resonators are in different positions.
The drivers side is to far back and does not want to slide any further onto the pipe. As a result the I can not get the over the axle pipe and muffler on.
On the passenger side. I am closer...but I still think it need to go up a lot further.
So some questions:
I assume that the bends in the head pipes should be somewhat symmetrical.
Haw far should the pipes go into the resonators and mufflers (they are in a bout two inches now)
Should the resonator hanger be on the outlet of and act as the clamp or on the over the axle pipe.
Linkback: https://forum.e-bodies.org/exhaust/17/exhaust-install-problems-updated-with-video/6380/
« Last Edit: May 24, 2018, 07:06:25 AM by Cudajason »
1974 Cuda. 360/727.  Yes its pink, not its not my wife's car!  Yes I drive it.
proxy in Exhaust Install Problems - updated - with Video! in Exhaust
Offline anlauto
  • Trade Count: (5)
  • E-Body Wizard
  • Credits: 17080
  • Life is like a box of chocolates....
    • Share Post
    • www_sm in Exhaust Install Problems - updated - with Video! in Exhaust
xx in Exhaust Install Problems - updated - with Video! in Exhaust
Re: Exhaust Install Problems
« Reply #1 on: April 14, 2018, 09:48:55 AM »
Probably have to shorten your head pipes :alan2cents:
Offline 1 Wild R/T
  • Trade Count: (0)
  • Six Pack
  • Credits: 6710
    • Share Post
« Reply #2 on: April 14, 2018, 12:42:15 PM »
 :iagree: And a little tip, put bits of masking tape on the pipes to give you a reference on how far the pipe is in the muffler.... If it's to deep it will restrict exhaust flow & if it's not deep enough it may leak... Or fall apart... Little bit of tape gives you a reference & can be removed without a trace...
Offline anlauto
  • Trade Count: (5)
  • E-Body Wizard
  • Credits: 17080
    • Share Post
« Reply #3 on: April 14, 2018, 06:08:42 PM »
Tip #2 when fitting the exhaust...a little bit of grease on the pipe helps lessen aggravation  :alan2cents:
Offline Cudajason
  • Trade Count: (1)
  • Big Block
  • Credits: 1010
  • Hey....
    • Share Post
« Reply #4 on: April 14, 2018, 06:30:52 PM »
Yeah that's what I am thinking.
good tip....I have been using a sharpie for that purpose.
You serious about that Clark [in my best cousin Eddie voice]
Offline anlauto
  • Trade Count: (5)
  • E-Body Wizard
  • Credits: 17080
    • Share Post
« Reply #5 on: April 14, 2018, 06:41:25 PM »
I use a little bit of grease all the time, or even WD40 :dunno:
Online 6bblgt
  • Trade Count: (1)
  • Six Pack
  • Credits: 5850
    • Share Post
« Reply #6 on: April 16, 2018, 11:38:25 AM »
is it possible you have Challenger headpipes in a 'cuda?  :dunno: they're 2" longer
211-250318130150 in Exhaust Install Problems - updated - with Video! in Exhaust
Offline anlauto
  • Trade Count: (5)
  • E-Body Wizard
  • Credits: 17080
    • Share Post
« Reply #7 on: April 16, 2018, 11:48:18 AM »
That's what I was thinking....I've ran into that issue before....
Offline Burdar
  • Trade Count: (0)
  • Six Pack
  • Credits: 7860
    • Share Post
« Reply #8 on: April 16, 2018, 02:09:16 PM »
Start at the back and work your way forward.  :alan2cents:
CHAL2 in Exhaust Install Problems - updated - with Video! in ExhaustOWEN in Exhaust Install Problems - updated - with Video! in ExhaustDART in Exhaust Install Problems - updated - with Video! in Exhaust
Offline Cudajason
  • Trade Count: (1)
  • Big Block
  • Credits: 1010
  • Hey....
    • Share Post
« Reply #9 on: April 18, 2018, 05:24:44 PM »
I thought that too! Manufacturer says no. I specified for a cuda, called talked to them, and they said the numbers and measurements were correct.
I think I will start buy cutting 2 inches off the head pipes (after I measure it all again).
Offline Cudajason
  • Trade Count: (1)
  • Big Block
  • Credits: 1010
  • Hey....
    • Share Post
« Reply #10 on: April 18, 2018, 05:27:36 PM »
I think I will try that too before cutting.  At leas I can verify the mufflers and over the axel pipes will fit.
On the passenger, with the two piece head pipe there is lots of room for play.  On the drivers side, not so much, but enough.
Now I just need to find some time to actually work on it...crazy busy at work and currently out of town until Saturday morning.
Offline Adams1stCuda
  • Trade Count: (0)
  • Leaning Tower of Power
  • Credits: 490
    • Share Post
« Reply #11 on: April 19, 2018, 12:16:48 PM »
Sorry, no knowledge to impart, but what exhauset set did you get?  Assuming factory to factory manifolds?
Offline Cudajason
  • Trade Count: (1)
  • Big Block
  • Credits: 1010
  • Hey....
    • Share Post
« Reply #12 on: April 19, 2018, 02:47:26 PM »
I would rather not say at this point...yes factory manifolds with factory pipes (72-74 two piece head pipes).
Offline jimynick
  • Trade Count: (0)
  • Six Pack
  • Credits: 7550
  • If you've got to ask, you don't understand!
    • Share Post
« Reply #13 on: April 19, 2018, 09:04:16 PM »
Jason, although based on the photos it looks like the pipe was going in deep enough, if it'd help, we have a pipe expander and an electric impact you could borrow if they'd help. I'd also only cut one inch off that pipe and if it needs it, then cut the other off. Easy to cut, not so easy to stretch, eh?  :cheers:
Offline Cudajason
  • Trade Count: (1)
  • Big Block
  • Credits: 1010
  • Hey....
    • Share Post
« Reply #14 on: April 24, 2018, 07:02:59 PM »
Thanks Ian.  I have a pipe expander and impact...tried that, it helped a bit.
Right now I am trying to get one of the one of the resonators off, its on there good.
In think i need more heat.
xx
Accurate Exhaust 15% Off OR Free Shipping on Exhaust Systems
Started by moparmadman69
Last post August 15, 2017, 01:52:21 PM
by moparmadman69
xx
318 Single exhaust to TTI dual exhaust [through valance]
Started by GoodysGotaCuda
Last post June 21, 2017, 03:33:58 PM
by MoparLeo
sad
Bad day for the cuda - updated pics of carnage
Started by torredcuda
Last post June 28, 2018, 04:47:59 PM
by torredcuda
question
Glove Box knob / cylinder assembly (updated)
Started by Katfish
Last post June 28, 2017, 07:32:41 PM
by EV2RTSE
xx
Hemi intake manifold installation issues - help :( *UPDATED*
Started by Mopsquad
Last post April 23, 2018, 07:02:34 PM
by Topcat
