avatar_torredcuda
Best way to remove urethane from window mouldings?
Started by torredcuda, November 26, 2023, 10:37:57 AM
torredcuda
I have some mouldings caked with black urethane from some previous owner probably trying to fix  leak  ::) , what tricks for easliy removing it - laquer thinner or ???
Jeff   `72 Barracuda 340/4spd
Northeast Mighty Mopar Club
I cut off what I can and then wipe off whats left with lacquer thinner. You almost need a full body condom for that job it seems.
1970Cuda
I would agree with Acetone, as I don't think Lacquer thinner will work. You might also try MEK, if your state allows it. And I have found the best luck combining mechanical release with chemical. Seems to work better - IMO.
