Can you help ID these?
Started by 7E-Bodies, April 18, 2020, 03:59:03 PM
7E-Bodies
Got the nail clippers, lol. But the other two? Isolation is killing memory cells.
Idle solenoid, washer pump and nail clipper!
 :iagree: Carb Idle solenoid and washer pump
7E-Bodies
Thanks!  I'm guessing my washer pump is toast. Anything out there aftermarket?
The idol stop solenoid is where the money is at. Though the bracket looks completely odd, the solenoid itself appears to be the same as the ones used on 1971 440+6 cars :rubeyes:
73_Cuda_4_Me
I was able to tear my washer pump down, clean it and re-lube it, put it back together, and works like a charm! Very small screws!
BS23H3B
7E-Bodies
I saw the tiny screws and am good with that as an electronics repair geek, it's just that the nylon part seems broken.
6bblgt
1970 (CARTER AVS) 440HP 4bbl and 340 4bbl cars used the above style idle stop solenoid (can't remember if the bracket is the same  :thinking:) with the bolt on clamp/bracket - still pricey
HEMI, 440+6, 340+6 & '71 340 4bbl use an idle stop solenoid with an attached bracket & big price tag
there are round & hexagon plungers for both style & probably point to a specific application
6bblgt
the washer pump is readily available & there are a number of slightly modified versions that will work (depending how "correct" your project needs to be)
for example:
https://www.ebay.com/itm/MOPAR-JEEP-AMC-1971-1996-NEW-Washer-Pump-MADE-IN-USA/313056080125?epid=75282618&hash=item48e398b0fd:g:1TkAAOSwvylbVBWU
Oh yea I forgot about the bracket being attached  :headbang:
HEMICUDA
Quote from: anlauto on April 18, 2020, 04:37:04 PM
Huh? Looks like a solenoid with the correct bracket for the 70 440 4 bbl to me. :drunk:  No where near the value of the correct one for a 71 6bbl. The 4429 solenoid is the "big money" one that could be as high as $600 for a good original, no clue what an NOS 4429 would sell for.
