normal_post in Holley sniper question  in Engine, Transmission & Rear End Author Topic: Holley sniper question  (Read 612 times)
Offline fireguyfire
  • index in Holley sniper question  in Engine, Transmission & Rear End
  • Credits: 4040
xx in Holley sniper question  in Engine, Transmission & Rear End
« on: November 16, 2019, 08:08:47 PM »
Unpacked the Holley sniper kit I bought for my 383 and am familiarizing myself with the parts of the system.
One thing isnít mentioned in the manual, and Iím sure Iím not looking close enough, but thereís no instruction on removing the manual fuel pump and also, there doesnít appear to be a ďblanking plateĒ in the kit either to block off the fuel pump opening.
Iím surprised there isnít one provided in the kit.
Can anyone sort me out on this?
Linkback: https://forum.e-bodies.org/engine-transmission-and-rear-end/4/holley-sniper-question/13714/
Offline larry4406
  • Small Block
  • Credits: 1880
Re: Holley sniper question
« Reply #1 on: November 17, 2019, 03:32:33 AM »
Pull the pump, remove the pushrod, install a blank cover with gasket.  Years ago I bought a blank off cover from Direct Connection.
Offline TheAutoArchaeologist
  • Leaning Tower of Power
  • Credits: 630
  • Hunting cool cars in barns
    • Auto Archaeology
« Reply #2 on: November 17, 2019, 09:13:48 PM »
The Sniper kit has just everything associated with the system itself.  The old fuel system and it's components are up to you.
Here's the blockoff plate.
https://www.summitracing.com/parts/sum-402035/overview/make/chrysler
Ryan Brutt
The Automotive Archaeologist
TheAutoArchaeologist@yahoo.com
www.barnfinds.org
Offline fireguyfire
  • Credits: 4040
« Reply #3 on: November 17, 2019, 09:40:18 PM »
Cheers!
Offline fireguyfire
  • Credits: 4040
« Reply #4 on: November 21, 2019, 09:52:17 AM »
So the guy at the performance shop where I bought my blanking plate said that a lot of guys that are sticklers for originality but want to add the EFI kits are running the fuel lines through a gutted old fuel pump and from there to the EFI head.
Has anyone on here done that?
Online Chryco Psycho
  • Credits: 30120
« Reply #5 on: November 23, 2019, 08:20:47 PM »
Not sure why , it clearly will not be original , just another game to play . the fear would be having the diaphragm fail & fill the crankcase with fuel , why take the risk??
1-190417082201 in Holley sniper question  in Engine, Transmission & Rear End
Offline fireguyfire
  • Credits: 4040
« Reply #6 on: November 23, 2019, 08:28:33 PM »
I agree; thought Iíd bring it up for discussion
  • Credits: 30120
« Reply #7 on: November 23, 2019, 09:12:12 PM »
pump diaphragms are not designed for 55 psi
Offline 73440
  • Credits: 1460
« Reply #8 on: November 24, 2019, 07:12:44 AM »
Are you talking of just using an gutted fuel pump with lines running thru the pump for looks ?
I've seen some Harley's with fake kick starters pedal and arm for just looks.
Offline fireguyfire
  • Credits: 4040
« Reply #9 on: November 24, 2019, 07:33:39 AM »
Thatís what he said; you disassemble and gut the fuel pump so it just free flows through it.
Sounds like a big recipe for a leak to me.
  • Credits: 30120
« Reply #10 on: November 24, 2019, 05:46:35 PM »
NO way I would do that , which shop was telling you about it ?
Offline fireguyfire
  • Credits: 4040
« Reply #11 on: November 24, 2019, 06:59:49 PM »
Just a parts place; guy behind the counter mentioned heíd heard people are doing this; definitely didnít recommend it himself
Offline 73440
  • Credits: 1460
« Reply #12 on: November 24, 2019, 08:14:38 PM »
If someone was to do it using a fuel line inside the pump hidden and no opening into the engine if they wanted the fuel pump look.
Holley Sniper
Started by BillR1212
Last post August 07, 2018, 03:04:13 PM
by RUNCHARGER
Holley Sniper EFI
Started by 303 Mopar
Last post July 24, 2018, 02:13:27 PM
by Strawdawg
Holley Sniper and Tech support praise
Last post September 09, 2018, 08:36:04 AM
by BillR1212
Holley Sniper ECU / Dakota Digital VHX Control Box Locations
Started by ledphoot
Last post March 04, 2019, 01:06:09 PM
by Chryco Psycho
Shaker base modification with Holley Dominator intake question
Started by usraptor
Last post January 29, 2018, 07:57:22 PM
by Chryco Psycho
