hot_post in fiberglass and bondo question in Body Shop Author Topic: fiberglass and bondo question  (Read 269 times)
Offline cuda hunter
  • Six Pack
  • index in fiberglass and bondo question in Body Shop
  • Credits: 10310
    • Sims Custom Homes
clip in fiberglass and bondo question in Body Shop
« on: May 22, 2020, 11:32:08 PM »
I have some coronet R/T scoops that are fiberglass.
they have had the R/T inset insignia filled with bondo.
How do I remove the bondo?
how do I remove the paint from the fiberglass?
I have two right hand scoops. would like to find a left hand scoop.
anyone know where to find the little white rubber cushions and the special nut?
Linkback: https://forum.e-bodies.org/body-shop/5/fiberglass-and-bondo-question/16460/
Offline cuda hunter
  • Six Pack
  • Credits: 10310
    • Sims Custom Homes
xx in fiberglass and bondo question in Body Shop
Re: fiberglass and bondo question
« Reply #1 on: May 22, 2020, 11:47:58 PM »
Ok, I can't find parts number
 3446052
42203A
40-2655 6B-1
any help out there?
I think it's a  70 coronet r/t  but can't find part number or picture of this scoop.
Offline anlauto
  • Trade Count: (9)
  • Credits: 34800
  • Life is like a box of chocolates....
    • www_sm in fiberglass and bondo question in Body Shop
« Reply #2 on: May 23, 2020, 05:23:29 AM »
Is it just the pictures, or is one smaller then the other ? You could likely remove the bondo pretty quick with a small torch :alan2cents: or carefully scrape it out. :dunno:
Offline torredcuda
  • Credits: 4710
  • Mopar or no car!
« Reply #3 on: May 23, 2020, 05:51:14 AM »
Some paint strippers will soften body filler but they have changed a lot due to EPA/health issues so not sure if newer ones will still work. I would get a small can of fiberglass safe stripper and try it.
Jeff   `72 Barracuda 340/4spd
Northeast Mighty Mopar Club
https://www.facebook.com/groups/1486087201685038/
Offline anlauto
  • Trade Count: (9)
  • Credits: 34800
« Reply #4 on: May 23, 2020, 05:59:31 AM »
Does bondo stick better or worse to fiberglass then steel ?  I guess it also depends on what they did to prep the fiberglass, hopefully not destroy the R/T area..
Offline cuda hunter
  • Six Pack
  • Credits: 10310
    • Sims Custom Homes
« Reply #5 on: May 23, 2020, 07:26:20 AM »
I'm not sure what they did to prep the fiberglass before bondo. Probably nothing.
These came off the same super bee that had my wing on it.
I"ll go to the car stores today and see if I can find some fiberglass safe stripper.  Try that first.
They are both the same size. Must be the picture angle.  Both the same side and part number.  I'm trying to find a drivers side.
Online 6bblgt
  • Trade Count: (2)
  • Six Pack
  • Credits: 14970
they are not exactly fiberglass - they are PIM (Plastic Injection Molding), RPIM (Reinforced Plastic Injection Molding) or some other similar acronym
https://en.wikipedia.org/wiki/Injection_moulding
it is the same material SHAKER bubbles are made of (RAMCHARGER/340 Swinger hood scoops, '70 Charger R/T door scoops, '71-'72 AIRGRABBER hood inserts, etc.)
they have the texture/structure of fiberglass reinforced drywall
 :iagree: you will have to see what affects the bondo without damaging the part & scrape out the filler  :takealook: been there, done that
the part number on cast and molded parts are usually NOT the number in a parts catalog - the number is changed once the part is modified/machined or sold as an assembly with clip/screws attached (or chromed & painted in the case of mouldings/emblems)
1970 Coronet R/T:
ORNAMENT, Qtr Outside Louver (23-34-334) # 3446 052 / 3446 053
Nut # 9420 218
NAME PLATE, Qtr, Outside Ornament (23-34-238) # 3445 919 (same as used on 1970 Charger R/T door scoop)
« Last Edit: May 23, 2020, 08:50:27 AM by 6bblgt »
211-250318130150 in fiberglass and bondo question in Body Shop
Offline cuda hunter
  • Six Pack
  • Credits: 10310
    • Sims Custom Homes
« Reply #7 on: May 23, 2020, 08:50:03 AM »
That makes sense as to why I can't find the part number reference anywhere.
Offline JS29
  • Trade Count: (3)
  • Credits: 24750
« Reply #8 on: May 23, 2020, 12:52:50 PM »
@cuda hunter  There is a stripper made for modern bumper covers, Try that.  :alan2cents:
Offline cuda hunter
  • Six Pack
  • Credits: 10310
    • Sims Custom Homes
« Reply #9 on: May 23, 2020, 03:15:18 PM »
I looked everywhere in town and all I can find is this new formula that does not include methyl chloride.  Everyone says it really sucks and will not take the multiple layers of lacquer paint or bondo off of these scoops.
Can anyone tell me different?  I don't want to waste 25 bucks to get a product that everyone says won't work.
Offline Racer57
  • Credits: 3100
« Reply #10 on: May 23, 2020, 08:57:49 PM »
Why not just sand it ?
Online 6bblgt
  • Trade Count: (2)
  • Six Pack
  • Credits: 14970
« Reply #11 on: May 23, 2020, 09:12:23 PM »
I don't think paint stripper is the answer it usually does nothing to bondo - you are just going to have to chisel it out & if it didn't adhere well to the paint, evidenced by the "R/T" crack out-line, maybe you'll be lucky and it will "pop" out as a large piece(s) - maybe with some encouragement from the backside where the emblem mounting holes are
I'd try some soap & water or maybe some WD-40 to creep into the existing crack/separation (think "mold release")  -  don't try to flex the part, it's pretty rigid & will crack
Offline JS29
  • Trade Count: (3)
  • Credits: 24750
« Reply #12 on: May 24, 2020, 12:54:32 PM »
They say (bondo) body filler absorbs water, plastic part wont rust. Maybe soak it in water, it might act as a releasing agent.   :alan2cents:
Offline cuda hunter
  • Six Pack
  • Credits: 10310
    • Sims Custom Homes
« Reply #13 on: May 24, 2020, 12:59:22 PM »
Last resort.
Offline Bullitt-
  • Six Pack
  • Credits: 4810
  • If it ain't broke I can't afford it.
« Reply #14 on: May 24, 2020, 01:13:03 PM »
I'd think a Dremel with wire wheel would get the job done...
.                                               Doin It Southern Syle        9210059a9782f3876586702e3770db8b in fiberglass and bondo question in Body Shop
The Dreaded Bondo Worm...
Started by anlauto
Last post October 29, 2019, 02:06:53 PM
by 7E-Bodies
Fiberglass repair
Started by Cbridgewater
Last post May 24, 2020, 04:07:34 PM
by Marty
Fiberglass hood
Started by Blake129
Last post July 28, 2019, 08:11:26 PM
by Cudakiller70
fiberglass Challenger fenders
Started by ec_co
Last post June 18, 2017, 06:00:09 AM
by ec_co
Challenger Fiberglass Hood
Started by VCODE
Last post April 30, 2018, 04:49:06 PM
by VCODE
