normal_post in Interchangeable tube seats in Wheels, Tires, Brakes, Suspension & Steering Author Topic: Interchangeable tube seats  (Read 210 times)
Offline bc3j
  • Small Block
  • index in Interchangeable tube seats in Wheels, Tires, Brakes, Suspension & Steering
  • Credits: 1470
xx in Interchangeable tube seats in Wheels, Tires, Brakes, Suspension & Steering
« on: August 01, 2020, 08:26:29 AM »
Are the tube seats on a cast iron master cylinder interchangeable with an aluminum master cylinder? Is it possible to install an internal residual pressure valve from a cast iron master into an aluminum master? I have a RPV from my drum master and was wondering if it would fit in the aluminum master now on the car.
Linkback: https://forum.e-bodies.org/wheels-tires-brakes-suspension-and-steering/12/interchangeable-tube-seats/17600/
Offline 1 Wild R/T
  • Credits: 10210
Re: Interchangeable tube seats
« Reply #1 on: August 01, 2020, 08:55:20 AM »
Doubtful... The brass seat may fit but the pocket for the residual pressure valve probably isn't there... It would be extra machining steps for no reason.... Manufacturers don't  do extra steps for no reason....
Just add an in line valve..
https://www.summitracing.com/parts/wil-260-13784?seid=srese1&gclid=Cj0KCQjwpZT5BRCdARIsAGEX0zkPaj4Xz-w3uUS-7dH9suQaSY0wbr20hsMEiq8Zq53e8pfspnpi2uQaAl40EALw_wcB
Offline Chryco Psycho
  • Credits: 33320
« Reply #2 on: August 01, 2020, 09:09:10 AM »
could try , te brass seats are easy to pull , it is just a small rubber valve beind
1-190417082201 in Interchangeable tube seats in Wheels, Tires, Brakes, Suspension & Steering
Offline bc3j
  • Small Block
  • Credits: 1470
« Reply #3 on: August 01, 2020, 10:18:24 AM »
I suspected that might be the case. I donít have that intricate knowledge base like you guys. Thanks
Is a 71-2 B-Body K Member the same, interchangeable, with a 70-74 E-Body?
Started by chryslers4ever
Last post February 11, 2019, 03:48:22 PM
by chryslers4ever
Inline Tube
Started by nicka
Last post July 28, 2020, 08:37:54 AM
by nicka
904 Dipstick / Tube
Started by Cudajason
Last post September 08, 2020, 08:08:42 AM
by Cudajason
Lock out tube
Started by 61K T/A
Last post February 02, 2017, 07:49:45 AM
by Cuda Cody
Diff tube stamps
Started by Mopar5
Last post April 22, 2019, 07:40:43 AM
by Mopar5
