normal_post in  440 stroker piston for 7.1 rods ? in Engine, Transmission & Rear End Author Topic: 440 stroker piston for 7.1 rods ?  (Read 221 times)
Offline BigSig 6 Barrel
  • Leaning Tower of Power
  • Credits: 310
xx in  440 stroker piston for 7.1 rods ? in Engine, Transmission & Rear End
« on: August 01, 2020, 10:19:31 PM »
Hello ...  question for the engine savvy among us
Does anyone make a "pump gas/steetable" RB / 4.15 stroker PISTON, that will accommodate the longer 7.1 rod with .990 pins?
also, (if it somehow matters) . . . my crank and 7.1 rods have a smaller -.050 journal.
or, do I need a longer stroke to use these rods?
Any help would be greatly appreciated !
Linkback: https://forum.e-bodies.org/engine-transmission-and-rear-end/4/-440-stroker-piston-for-7-1-rods/17609/
« Last Edit: August 02, 2020, 11:25:59 AM by BigSig 6 Barrel »
Offline Chryco Psycho
  • index in  440 stroker piston for 7.1 rods ? in Engine, Transmission & Rear End
  • Credits: 33320
Re: 440 stroker piston for 7.1 rods ?
« Reply #1 on: August 01, 2020, 10:35:01 PM »
Did you ceck 440 source , I believe tay carry pistons for te combo
1-190417082201 in  440 stroker piston for 7.1 rods ? in Engine, Transmission & Rear End
  • Credits: 310
« Reply #2 on: August 01, 2020, 10:38:26 PM »
  No I haven't . . . Thanks, I'll check them out!
UPDATE:  Dead end . . . I looked, and didn't see any  . . . that is . . . until you hit 4.25 stroke
« Last Edit: August 02, 2020, 11:21:09 AM by BigSig 6 Barrel »
  • Credits: 33320
« Reply #3 on: August 03, 2020, 09:34:01 AM »
I know Diamond is Mopar bias & can build you a custom piston buy modifyin pin location .
https://diamondracing.net/
  • Credits: 310
« Reply #4 on: August 03, 2020, 08:31:53 PM »
Thanks Neil . . . . It's guys like you that make this such a great forum to hang out at.
I don't say much, mostly cause I don't know these e-bodies the way some of you do, but I do check in almost every day to see whats up, and learn from the collective knowledge here.
Custom pistons might be the best solution to my problem, if not for the "wallet melting' expense . . .
Might just give up on the long rod build idea, and go with a shorter rod combo like what everyone else uses . . . .  and probably for less $$$
Offline RUNCHARGER
  • Trade Count: (7)
  • Credits: 33100
« Reply #5 on: August 03, 2020, 09:01:01 PM »
It's probably only about $100 for the change. I would call them and find out before changing directions.
Sheldon
  • Credits: 33320
« Reply #6 on: August 03, 2020, 10:06:22 PM »
 :iagree:
  I bet they have a blank that works & they just have to machine the piston pin at a slightly different height to make it work !
 I am a strong believer in long rod combos  :bigthumb:
440 Piston Pic!
Started by Ebbs
Last post January 10, 2019, 07:04:21 AM
by RUNCHARGER
Piston choices
Started by Matt13
Last post September 29, 2020, 06:47:17 PM
by RUNCHARGER
Help, ID piston and rod type
Started by 61K T/A
Last post March 04, 2017, 02:04:16 PM
by Chryco Psycho
Piston ring files
Started by Mrbill426
Last post November 21, 2020, 10:31:36 AM
by Mrbill426
Gapless Piston Rings
Started by Roadman
Last post February 16, 2017, 08:05:31 PM
by Chryco Psycho
