normal_post in 1968-1970 340 exhaust manifolds, Gasket Air Cleaner in What's It Worth? Author Topic: 1968-1970 340 exhaust manifolds, Gasket Air Cleaner  (Read 214 times)
Offline 71340RT
  • Small Block
  • index in 1968-1970 340 exhaust manifolds, Gasket Air Cleaner in What's It Worth?
clip in 1968-1970 340 exhaust manifolds, Gasket Air Cleaner in What's It Worth?
« on: January 22, 2023, 12:17:39 PM »
I have a set of 1968-1970 340 HP exhaust manifolds and wondered what they are worth. The heat riser is blocked off. They are not all pitted and used on one of my cars till I pulled the car apart for a Gen3 hemi swap. I have the drivers side heat shield gasket and wondered what it might be worth also. The other item I have is a unsilenced air cleaner and new 440 magnum pie tin. The air cleaner is stamped made in Canada on the underside. Here are pictures and thanks for any help.
Linkback: https://forum.e-bodies.org/whats-it-worth/15/1968-1970-340-exhaust-manifolds-gasket-air-cleaner/27373/
1971 Challenger RT 340 auto 1 of 731
1973 Challenger Rallye 392 Hemi A41 4 speed automatic
2016 Dodge Challenger Scat Pack 392 Hemi auto
Offline Rdchallenger
xx in 1968-1970 340 exhaust manifolds, Gasket Air Cleaner in What's It Worth?
Re: 1968-1970 340 exhaust manifolds, Gasket Air Cleaner
« Reply #1 on: January 22, 2023, 01:21:30 PM »
The manifolds I’ve seen go anywhere from $600-$900 depending on condition. This has been a year or two ago.
The gasket I’ve seen go for $200-$300 I think
Online Floyd
  • Trade Count: (8)
« Reply #2 on: January 22, 2023, 03:15:41 PM »
Agree w/Rdchallenger on the above.  The pie pan could be worth $150+ to the right guy.  I think they’ve been out of production for awhile but that would obviously change if they come back in supply.  I’d guess $175-200 on the air cleaner.
Online anlauto
  • Trade Count: (19)
  • Life is like a box of chocolates....
    • www_sm in 1968-1970 340 exhaust manifolds, Gasket Air Cleaner in What's It Worth?
« Reply #3 on: January 22, 2023, 03:45:36 PM »
I'd be interested in the heat shield if you want to ship to Canada :fingerscrossed:
Offline 71340RT
  • Small Block
« Reply #4 on: January 22, 2023, 04:19:49 PM »
Alan if the other person that was 1st doesn't buy it I will ship to Canada for you.
Jeff
Online anlauto
  • Trade Count: (19)
« Reply #5 on: January 22, 2023, 04:22:31 PM »
Sounds good, thanks for at least considering it  :worship: :drinkingbud:
Started by jt4406
Last post April 24, 2021, 08:07:23 AM
by jt4406
1970 BB HP exhaust manifolds
Started by Sleepychallenger
Last post August 05, 2017, 07:30:33 AM
by Cuda Cody
1970 AAR Cuda exhaust manifolds 2863553 & 2863549
Started by 76orangewagon
Last post September 16, 2018, 12:45:24 PM
by anlauto
Exhaust manifolds
Started by bballfan1
Last post March 24, 2022, 02:22:24 PM
by benguin
68-70 HP 340 Exhaust Manifolds
Started by 70 Challenger Lover
Last post March 01, 2022, 07:22:51 PM
