Installing fuel pump
Started by nsmall, September 12, 2017, 11:27:26 PM
nsmall
Yes I'm really asking this.
So when it comes to installing this fuel pump I'm assuming I just go ahead and keep cranking on the bolts and it will work its way in there as it doesn't fit flush.
Also when it comes to the gasket I'm assuming a little goop on both sides is a good idea?
Thanks
Katfish
I think it should sit a little more flush.
Maybe turn the engine over a little and retry.
The pump arm rides directly against the cam on a SB.
If you tightened it the way it is you'll only activate the pump arm.....no harm done. :alan2cents:
Burdar
There is a lot of force on that pump arm.  It won't sit flush until the bolts are tight.
 :iagree:  Yup, just tighten it until it's flush.  I put a little cam break-in lube on the contact part of the arm too.  Might not be needed, but it doesn't hurt to have a little extra protection on the first start up.  But I think your cam is already broke in so you are probably fine without it if you already installed the pump.
CudaMoparRay
Learn something new every day. I never would have thought to continue tightening it as it seems counter intuitive. Great info to know, thanks guys
HP_Cuda
Since it's not flush make sure you are not cross threading before torquing them down.
1975 Dodge Power Wagon W200
Roadman
Quote from: HP_Cuda on September 13, 2017, 04:16:06 PM
                        :iagree:  You can turn the motor to the point where you are on the low point of the cam lobe, but will still have pressure on the spring in the pump. Start bolts straight .    :rebelflag"
RUNCHARGER
Keep tightening and I use gasket sealer on both sides of the gasket at that spot.
Sheldon
nsmall
Thanks everyone. Followed your directions...worked great. My car has been painted.  I'm 95% done restoring the parts.  Here are two teaser photos...
RUNCHARGER
Sheldon
303 Mopar
Quote from: Roadman on September 13, 2017, 05:36:03 PM
JS29
A crossed thread is A sure thread!!!!!!   :barf:
That color looks GOOD!!!!!   :1place:
HP_Cuda
LOL 303
If you are going to do it don't do it half assed.
