normal_post in LA 360 - Blocking Intake Heat Crossover in Engine, Transmission & Rear End Author Topic: LA 360 - Blocking Intake Heat Crossover  (Read 187 times)
Offline GoodysGotaCuda
  • index in LA 360 - Blocking Intake Heat Crossover in Engine, Transmission & Rear End
  • Credits: 1280
xx in LA 360 - Blocking Intake Heat Crossover in Engine, Transmission & Rear End
« on: August 09, 2018, 05:24:07 PM »
What is your method of blocking the intake heat crossover?
I have an Edelbrock Performer RPM to install and would like to go ahead and kill the port. I've seen people say they JB weld it up, pack the head with aluminum foil, use thin sheet metal under the gasket.
What works for you? :wrenching:
Linkback: https://forum.e-bodies.org/engine-transmission-and-rear-end/4/la-360-blocking-intake-heat-crossover/8006/
1972 Barracuda - 5.7L Hemi, T56 Magnum
1976 Dodge D100 - Warlock - 360/727/2wd
2016 BMW X1
2016 Subaru WRX
Online kawahonda
  • Credits: 1580
Re: LA 360 - Blocking Intake Heat Crossover
« Reply #1 on: August 09, 2018, 05:48:02 PM »
I wouldn’t kill the port unless you need to.
Doesn’t the RPM already not hve a cross over?
1970 Dodge Challenger A66
Offline 76orangewagon
  • Trade Count: (5)
  • Credits: 2880
« Reply #2 on: August 09, 2018, 06:10:58 PM »
They sell gaskets with the cross over blocked off so you can leave the intake intake intact.
Ross
Online Cudajason
  • Credits: 650
  • Hey....
« Reply #3 on: August 09, 2018, 06:28:44 PM »
Finally coming back to the dark side and going old school on the CUDA...glad to hear it!!   :ohyeah: :ohyeah: :ohyeah: :ohyeah: :haha: :haha: :haha: :haha:
1974 Cuda. 360/727.  Yes its pink, not its not my wife's car!  Yes I drive it.
proxy in LA 360 - Blocking Intake Heat Crossover in Engine, Transmission & Rear End
  • Credits: 1280
« Reply #4 on: August 09, 2018, 06:49:26 PM »
Why would I need it? I don't have a thermostatic choke.
The AirGap doesn't have a crossover, the Performer RPM does.
I have run composite gaskets that blocked off the port in the past, they burned through.
The dinosaur motor I'm working on is in the Warlock  :deadhorse:
Offline Shane Kelley
  • Six Pack
  • Credits: 1350
« Reply #5 on: August 10, 2018, 06:34:15 AM »
I have had the gaskets blow out also and i'm a big fan of blocking the crossover off also. I see no need in heating up the intake manifold causing vapor lock among other things and yes i know what they are designed for. Doing also keeps the paint from burning the paint off painted manifolds. I cut a thin piece of sheetmetal and put it on the intake side of the gasket. You need to make sure it's almost aluminum can thin or it can hold the intake up and cause a vacuum leak on the nearest ports.
Offline Chryco Psycho
  • Credits: 13010
« Reply #6 on: August 10, 2018, 07:06:08 AM »
I use a section of the old gasket cut it to fit & glue it in place with silicone  :bigthumb:
1-190417082201 in LA 360 - Blocking Intake Heat Crossover in Engine, Transmission & Rear End
Valve Cover powder coat bubbling due to blocked crossover ?
Started by Racer57
Last post January 13, 2018, 09:14:05 AM
by RUNCHARGER
How do you heat your shop
Started by Shoooter
Last post January 13, 2018, 08:11:49 PM
by BIGSHCLUNK
Z-bar vs heat issue?
Started by Bluemonster71RT
Last post Today at 03:42:55 PM
by GrandpaKevin
Heat shields
Started by jlemler
Last post November 10, 2017, 04:45:59 PM
by 750-h2
Exhaust heat risers, yea or nay?
Started by ksierens
Last post April 07, 2018, 06:17:00 AM
by AAR#2
