normal_post in Where Do These Two Wires Go??? in Electrical & Audio Author Topic: Where Do These Two Wires Go???  (Read 272 times)
Offline Daveh
  • Credits: 1700
clip in Where Do These Two Wires Go??? in Electrical & Audio
« on: September 13, 2018, 08:06:10 PM »
Can someone tell me where these two wire go?  They are on the under dash wiring harness.  Thanks
Linkback: https://forum.e-bodies.org/electrical-and-audio/11/where-do-these-two-wires-go/8427/
Offline shawge
  • Small Block
  • index in Where Do These Two Wires Go??? in Electrical & Audio
  • Credits: 1740
xx in Where Do These Two Wires Go??? in Electrical & Audio
Re: Where Do These Two Wires Go???
« Reply #1 on: September 13, 2018, 08:23:51 PM »
They look like they are for door light and door ajar switches.
1970 Challenger, 451 MS3Pro EFI
Offline Chryco Psycho
  • Credits: 13650
« Reply #2 on: September 13, 2018, 09:14:31 PM »
 :iagree:   :bigthumb:
1-190417082201 in Where Do These Two Wires Go??? in Electrical & Audio
Offline Daveh
  • Credits: 1700
« Reply #3 on: September 14, 2018, 05:47:00 AM »
But I have a 71 with the door 3 pin style connectors.  Were different styles used on different sides.  3 PIN on the drivers and the spaded on the passengers side?
Also my 71 Challenger is a convertible so no dome light.  But I do have the under dash light.
« Last Edit: September 14, 2018, 06:08:14 AM by Daveh »
Offline 1 Wild R/T
  • Six Pack
  • Credits: 6720
« Reply #4 on: September 14, 2018, 07:11:13 AM »
Should have lights in the rear footwells.....
Online anlauto
  • Trade Count: (5)
  • Credits: 17110
  • Life is like a box of chocolates....
    • www_sm in Where Do These Two Wires Go??? in Electrical & Audio
« Reply #5 on: September 14, 2018, 07:42:19 AM »
So YES....in 1971 two different styles of door jamb light switches were used. 3 prong on the driver's side and 2 spade on the passenger side. In 1970 they used the same 2 spade switches on both sides.
Convertibles did not come with a dome light, however as mentioned those switches controlled the map light on the dash and two rear interior lights mounted in the rear interior panels.
Offline Claudia
  • Credits: 2140
« Reply #6 on: September 14, 2018, 07:57:32 AM »
Are the connectors on the driver or passenger side of the dash harness?
 :alan2cents: My '71 has a three pin barrel style connector for the driver side door switch and a dual spade terminal style connector for the passenger side.
Offline Daveh
  • Credits: 1700
« Reply #7 on: September 14, 2018, 08:07:44 AM »
Yes the wires will go over to that side so that is what I was thinking.  I can't find that button anywhere only the 3 pin type.
Does anyone know where I can get that kind?  Thanks
Offline Daveh
  • Credits: 1700
« Reply #9 on: September 14, 2018, 08:43:18 AM »
Great thanks.
best plug wires 440 with tti headers
Started by cam440
Last post July 17, 2018, 02:53:45 PM
by jordan
7mm vs 8mm spark plug wires
Started by usraptor
Last post July 10, 2018, 12:36:51 PM
by chargerdon
70 steering column wires
Started by culp71
Last post May 08, 2018, 01:03:02 PM
by TelisSE440
Resto - Which length plug wires?
Started by Chris Pauluk
Last post October 12, 2017, 06:28:17 AM
by Chryco Psycho
WHAT COLOR SPARK PLUG WIRES
Started by B54SPEED
Last post September 14, 2018, 07:51:46 AM
by anlauto
