normal_post in Wheel balancing question? in Cuda & Challenger General Discussion (ROSEVILLE MOPARTS) Author Topic: Wheel balancing question?  (Read 326 times)
Offline 750-h2
  • Credits: 4800
xx in Wheel balancing question? in Cuda & Challenger General Discussion (ROSEVILLE MOPARTS)
« on: October 11, 2018, 08:47:41 AM »
I am about to get my new Good Year Polyglass tires mounted on my freshly painted rallye wheels. My question is, from the factory were the balancing weights installed on the outside or inside of the rallye wheels?  Thanks
Linkback: https://forum.e-bodies.org/cuda-and-challenger-general-discussion-roseville-moparts/2/wheel-balancing-question/8743/
Offline Chryco Psycho
  • index in Wheel balancing question? in Cuda & Challenger General Discussion (ROSEVILLE MOPARTS)
  • Credits: 15320
Re: Wheel balancing question?
« Reply #1 on: October 11, 2018, 09:01:05 AM »
 typically they are dynamically balanced so you would have weights on both sides covered by the trim rings
1-190417082201 in Wheel balancing question? in Cuda & Challenger General Discussion (ROSEVILLE MOPARTS)
Offline 750-h2
  • Credits: 4800
« Reply #2 on: October 11, 2018, 10:43:34 AM »
Thanks!
Offline 73_Cuda_4_Me
  • Credits: 2120
« Reply #3 on: October 11, 2018, 04:41:37 PM »
Just FYI... when I had my Coopers newly added 2 years ago, they (lube and tire shop) did the normal balancing, and I had shaking at 70 mph... had them re-balance them, and they said it was right on (so did the machine I watched them do it on!).
Last year I had the wheels 'road force balanced' at another place (that also does alignment) recommended by a friend, where they put them under a load while mounted to the machine, and they found the rallye rims out of balance (original 14's) by quite a bit, and at different spots than the original balance locations...
After I got the balance re-done under load last year, no problems up to and above the speed I can 'legally' drive... LOL
Good luck with them!
73 340 `Cuda 727 Auto on Column
BS23H3B
  • Credits: 15320
« Reply #4 on: October 14, 2018, 06:49:28 AM »
The other problem I have witnessed is even when the tires are balanced correctly the tire may not be round , I have seen as much as 1/4" step in the tread where the belts overlap on BFG tires for example
« Last Edit: October 14, 2018, 01:58:46 PM by Chryco Psycho »
Offline dodj
  • Credits: 3080
« Reply #5 on: October 14, 2018, 08:10:07 AM »
I have seen as much as 1.4" step in the tread where the belts overlap on BFG tires for example
From various posts in the last couple years, I'm starting to think you don't like BFGoodrich tires very much...lol
Back in the early 80's, they were the tire to have.
"Some guys think that having a better car makes them better than other guys, and those guys are right." -Top Gear
Offline RUNCHARGER
  • Trade Count: (6)
  • Credits: 13500
« Reply #6 on: October 14, 2018, 08:25:43 AM »
They were okay a few decades ago. I agree I don't like them much anymore. I bought a new 75 Road Runner and it had balance weights on the inside and outside of the wheels.
Sheldon
  • Credits: 15320
« Reply #7 on: October 14, 2018, 01:59:37 PM »
Ya think , ...... just experience talking !
Offline Swamp Donkey
  • Leaning Tower of Power
  • Credits: 860
« Reply #8 on: October 14, 2018, 07:11:43 PM »
One big ol Smokey burnout and those tires will be perfectly round.
1973 Cuda. 340 4 speed.
Offline BIGSHCLUNK
  • Credits: 4650
« Reply #9 on: October 14, 2018, 08:26:17 PM »
HEHEHEHE ol' BIGS still running his TA's    :haha:
question
Rallye Wheel Question On AAR
Started by Jim AAR
Last post October 30, 2017, 12:42:51 AM
by 6bblgt
Steering wheel experts question
Started by CudaMoparRay
Last post October 06, 2017, 06:41:00 PM
by RUNCHARGER
Rally Wheel Center Caps Question
Started by Jim AAR
Last post November 26, 2017, 02:12:07 PM
by js27
Wheel bearing /hub question, not mopar related
Started by Brads70
Last post July 06, 2017, 07:05:50 PM
by usraptor
New Cragar wheel And Tire Question With Pictures 71 Challenger Convertible
Started by Daveh
Last post April 18, 2017, 02:29:20 PM
by Daveh
