Need Orig Pic - SE Rear Window Interior Trim Screws
Started by TWS, February 09, 2023, 06:24:36 PM
TWS
In search of a pic and dimensions of an original screw used to secure the inside wide plastic window trim piece for a Challenger small SE rear window.
Thanks!
Headjam
Quote from: TWS on February 09, 2023, 06:24:36 PM
@TWS Definitely #8 Phillips oval head. Mine has two different lengths 3/4" and 5/8". A couple of the screws have flush washers which I like in that application. If you can find those, I would use them. If not, standard Phillips oval head. Length isn't critical as the screws are going into the fiberglass plug and there is additional clearance if needed.
TWS
