avatar_ebodyproducts
Drag link hitting oil pan
Started by ebodyproducts, December 08, 2025, 02:04:12 PM
ebodyproducts
I ran into an issue with the drag link hitting the oil pan bolt.
1971 cuda with 6.4 hemi.  Using stock K-frame and suspension.  I have TTI mounts and a Milodon oil pan.  Has anyone else encountered this?
It is hitting the oil pan drain plug when turning wheel all the way to the right.
E-Body Products
www.ebodyproducts.com
606-481-9014
Mopar5
I believe 440 source sells a drag link to correct this issue.
Skdmark
-Harlan Ellison
:stayinlane:
 I have read about similar issues several times.
  a couple of suggestions in this thread
https://forum.e-bodies.org/index.php?msg=320427
