Classifieds => Parts / Misc For Sale => Topic started by: Claudia on April 03, 2017, 08:57:07 AM
Plymouth Emblem
Battery Tray Support Brace
Front Shock Mounting Hardware Kit
Lower Steering Column Seal Retainer
Fuel Line Hardware Kit
Master Cylinder Brake Lines
Manual Master Cylinder Mounting Plate
Clutch Pedal Support Bracket
Hood to Cowl Seal
Main Drive Wiper Arm Linkage
Windshield Wiper Pivot
Front Windshield Lower Corner Trim Molding (LH)
Floor Heat Shield (approximately 6' x 4')
Black Carpet Set
Standard Dash Light Bar
Rallye Dash Switch Panel Woodgrain Fascia
Rallye Dash Gauge Cluster Woodgrain Fascia
Automatic Console Top Plate
Exterior Mirror Gasket Set
Ignition Switch (missing connector)
Key Buzzer Switch (missing terminal ends)
Ignition Key Lock Cylinder w/ Keys
Turn Signal Switch (missing connector)
Window Crank Handle
Interior Door Handle (LH)
Armrest Pull Cup Bracket
Chrome Door Lock Lever (set)
Dome Light Assembly
Vinyl Decal Application Kit (spray and gel)
Door Lock Cylinder Gasket Set (2 gaskets)
Door Lock Link Rod (LH)
Rear Quarter Glass Seals
Rear Quarter Glass (LH)
Rear Quarter Glass (RH)
Exterior Rear Lower Window Trim Piece (LH)
Exterior Rear Lower Window Trim Piece (RH)
Exterior Rear Upper Corner Window Trim Piece (LH)
Trunk Latch Striker Plate
Trunk Lid Latch Striker w / Mounting Hardware
Trunk Lid Latch
License Plate Light Lens
$600
