Technical Shop => Engine, Transmission & Rear End => Topic started by: redgum78 on February 13, 2020, 01:12:43 AM
Title: 727 kick down linkage
Post by: redgum78 on February 13, 2020, 01:12:43 AM
Hi all,
Can anyone confirm what kickdown linkage my 70 Challenger should have. 440 with 727.
When I google around it seem there are 2 versions;
Version 1 goes slotted rod on carb linkage- pivot on manifold- rod to bell crank on the 727 then another rod from bell crank to the trans lever.
Version 2 goes slotted rod on carb- pivot on manifold- long bent rod to lever on transmission.
Will either version work? I have found version 2 for sale locally but want to be sure it will do the job before I purchase.
Thanks
Title: Re: 727 kick down linkage
Post by: anlauto on February 13, 2020, 04:53:12 AM
The three piece linkage is correct for your 70 440.  :alan2cents:
I would assume the later one piece design would work. :dunno:
Post by: Bullitt- on February 13, 2020, 05:46:21 AM
I think about the threaded rod style for 440's  Imagine there's  variations to that
(https://www.rosevillemoparts.com/wp-content/uploads/2019/10/KL383.jpg)
https://www.rosevillemoparts.com/product/kick-down-linkage-70-71-e-body-440-4-bbl/
several styles that I wouldn't be able to tell apart
https://www.rosevillemoparts.com/?s=Kick+Down+Linkage&product_cat=0&post_type=product
Post by: headejm on February 13, 2020, 10:40:53 AM
@redgum78 (https://forum.e-bodies.org/mlist/redgum78_789)  The 1970 Challenger/Dart Service Manual has a lot of good information/photos on the various carburetor linkages. You can find the Service Manual on this site under “Resources”. Here is a photo showing the 383/440 4-barrel linkage.  :cheers:
Post by: redgum78 on February 13, 2020, 05:25:13 PM
You guys are legends, thanks for the assistance!
I downloaded the challenger manual a couple years ago, I looked in the carb section and in the transmission section for a picture of the linkage, who would have thought I had to look in the lube and maintenance chapter!
