Technical Shop => Electrical & Audio => Topic started by: Mrbill426 on October 17, 2020, 01:42:20 PM
Title: Igniton harness connector terminal
Post by: Mrbill426 on October 17, 2020, 01:42:20 PM
Does anyone make replacement connector terminal housings for the ignition switch harness connector?  I am referring to the "male" end that is on the dash harness that plugs into the steering column (ignition switch) harness.  I have looked on the Roseville site but don't see anything.   Maybe I am just missing it. :dunno: :dunno:
Title: Re: Igniton harness connector terminal
Post by: Mrbill426 on October 18, 2020, 11:23:16 AM
@Bullitt- (https://forum.e-bodies.org/mlist/bullitt_218) not even you Sir?  :huh:
Post by: Bullitt- on October 19, 2020, 08:19:16 AM
  :headbang:  No Luck today  ... I've searched for before as well
I'm guessing M&H has a patent they keep a tight grip on   :dunno:
Post by: Skdmark on October 19, 2020, 01:38:01 PM
Have you tried contacting Evans?
I've never dealt with them, but they may have loose connectors or can provide a lead on where to get one.
http://www.evanswiring.com/default.htm
Post by: Mrbill426 on October 22, 2020, 01:00:00 PM
@Skdmark (https://forum.e-bodies.org/mlist/skdmark_284)  No but I will give them a try; thanks.
Post by: Jay Bee on October 22, 2020, 02:26:25 PM
I've got some oddball connectors from Bill in the past but not the one you're looking for. Good Luck.
Post by: Mrbill426 on October 23, 2020, 11:21:32 AM
I contacted them and they only had the opposite terminal end, the ignition switch end, I need the dash harness end.   They don't make dash harnesses so that is probably why.
