What does it weigh ?
Started by Brads70, April 03, 2017, 09:57:01 AM
I found this information useful in selecting parts at times, though someone else might too?
Strange S60 Dana B-Body length with 4.10 with Eaton Truetrac Differential  (A-7) tapered wheel bearings 35 spline axles . Rotors and calipers not installed ( but with caliper brackets.)
= 204 LBS
Keisler A-41 (4L65E) w/ torque convertor, no oil-189 pounds
My back can confirm that Dana's are over 200 lbs.   :Thud:
Copied and pasted this from another Mopar site.
http://www.protouringmopar.com/showthread.php?685-What-does-it-weigh-Weigh-anything-you-have-and-post-it-up-here&highlight=weigh
That site has been down off and on so I'll copy and paste information on here "just in case"
--------E body parts:
Cuda fender- 33 pounds
Cuda front bumper- 15 pounds
Bumper bracket and bolts- 15 pounds
AAR cuda bumper- 5 pounds ( glass)
Challenger R/T hood, no inserts- 72 pounds
Challenger hood hinges with springs- 6.8 pounds
Flaming River iron manual box = 15lbs
Borgeson PS box = 21lbs
-------Engine parts:
6.1 Hemi Cyl Head Assembled -41 pounds
BIGS Holley 950 Stage 5 Carburetor- 8 pounds
Stock 70s SB starter: 14-17lbs(why mopar why!!!!)
90s magnum starter: 7lbs
--------Complete engines:
Gen 2 Viper V10- 620 pounds
2009 Ram 5.7 Hemi bare- 512 pounds
Low deck 470ci big block, all aluminum except block and with 7 quarts oil- 519 pounds
---------Transmissions:
Viper T-56- 121 pounds
Aluminum A-833 OD- 79 pounds
727 with TC oil drained out 170 lbs
-----------Axles:
741 case w/ 3.55 suregrip- 73 pounds
B body D60 bare housing- 68 pounds
= 204 LBS
-----------Springs/torsion bars:
Charger leaf springs- Left- 40 pounds, Right- 42 pounds
1.18 torsion bar- 12 pounds
hypercoil leaf spring- 10 pounds
Stock torsion bar- 8 pounds
-----------Brakes:
ZO6 vette brake rotor- 25 pounds
Stock loaded caliper- 10 pounds
Viper caliper- 8 pounds
Wilwood Dynalite- 4 pounds
Wilwood SL6 Caliper- 4 pounds
Wilwood 2 piece 13x1.25 rotor- 12 pounds
disc brake weight info
loaded calipers
Stock 10#
Viper 8#
Wilwood Dynalite 4#
Adapters
Stock 3.5
Viper 2.5
Wilwood 1
Spindles
Disc FJM 6.2
Drum 6.6
Disc A 8.4
Fatman 10.3
11.75 rotor 25#
Complete 11.75" assy
Stock-45
Viper-41.5
Wilwood-36.5
Rims
ET wheels LTIII 18X11 bare rim 28Lbs
http://www.etwheels.com/lt_iii.html
Quote from: Cuda Cody on April 03, 2017, 10:07:38 AM
I'd be curious to know what a stock Dana weighs? Strange advertises it to be lighter than a stock Dana?
