74 Challenger Fender Tag Help
Started by Mopar Crazy, December 15, 2023, 09:42:08 AM
Mopar Crazy
The car was originally Sherwood Green which should be G8.
Where it has the paint code my fender tag has KG8.
Does anyone know what the K stands for ?
and does anyone have a decoding sheet for 1974 they can share ? I have 69 to 84 but some of the codes are not in what I have.
Thank you
Blowout
K represents the year the paint was introduced/changed.  FC7 is 1970 Plum Crazy for example F being 1970. K being 1974.
318Stroker
The K means that exact shade of G8 was introduced for the 1974 model year. Could be slightly different than G8 introduced in previous years. F is the 70 model year, H is 71, G is 72, H is 73, and K is 74. They skipped I as it could  be confused with the numeral 1.
Quote from: 318Stroker on December 15, 2023, 10:13:48 AMThe K means that exact shade of G8 was introduced for the 1974 model year. Could be slightly different than G8 introduced in previous years. F is the 70 model year, H is 71, G is 72, H is 73, and K is 74. They skipped I as it could  be confused with the numeral 1.
.....now I know my "A"B"C"s or not.... :haha:
318Stroker
Quote from: anlauto on December 15, 2023, 10:27:15 AM
OOPS...Knew what I meant to type but didn't come out that way...I really butchered that post...
Mopar Crazy
wow great information.. Thanks for the replies.   :cheers:
cuda hunter
KG8 is called   Deep Sherwood Metallic  in 74.
