avatar_Brads70
1970 Challenger parking brake lever, need a picture?
Started by Brads70, May 13, 2017, 05:29:07 PM
shawge
It's probably the small spring inside the assembly as Alan said. I'll bet  :alan2cents: the spring is still hanging on in there.  When mine broke from being in the acid bath too long, I scrounged one from a set of springs from HF.
Edit: small spring here, from MegaParts kit
http://www.megapartsusa.com/proddetail.asp?prod=199-DR056A
Colored wiring diagrams
Wheel spreadsheet
BillyB
FYI. The exact bushing can be found at Grainger under the description of "nylon shoulder washer" here: https://www.grainger.com/product/GRAINGER-APPROVED-0-25-in-Nylon-6-6-Shoulder-4DCJ9
Replacing this bushing requires removing the release lever linkage at the rivet, but the shoulder washer does have the clearance to go over the bends in the linkage.
R/T's 4 R/P
It's not big bucks...but if anyone bought a box of the Grainger plastic grommets and wants to sell a few Pm me.
I may buy a box and try them out.
However, it appears the original version had a wide portion that allowed it to snap in place.
The Mega Parts kit has a rubber grommet, that works, but also can become dislodged if you pull the arm and it drags on the grommet.
70 R/T 440 6 Pack
70 T/A
70 SE R/T 383
2015 SRT
Ns1aar
Just bought a box of th bushings ill see what happens
DeathProofCuda
@Brads70 Did you ever get this issue resolved, and if so, what was the fix?
Quote from: DeathProofCuda on July 18, 2023, 12:37:57 PM
Humm to be honest I can't remember? I did source a replacement parking brake mechanism but it's still sitting on the shelf. Can't say I use the parking brake much being an automatic.
Sorry I know that's not much help.
Cassanth
I know this is an older thread, but I found it when researching my problems. I have ended up 3d printing my own, as that Grainger link doesn't see to go anywhere. Here are some pics of mine I made up.
