normal_post in 71 340 cuda w powersteering in Wheels, Tires, Brakes, Suspension & Steering Author Topic: 71 340 cuda w powersteering  (Read 280 times)
Offline culp71
  • Trade Count: (1)
  • Small Block
  • index in 71 340 cuda w powersteering in Wheels, Tires, Brakes, Suspension & Steering
  • Credits: 1140
    • Share Post
xx in 71 340 cuda w powersteering in Wheels, Tires, Brakes, Suspension & Steering
« on: September 14, 2018, 07:55:34 AM »
71 cuda, 340/727 with power steering, I got the front all aligned and it handles great.
but I have been noticing that when I am completely stopped with the vehicle running if I take my hands of the wheel, it will slowly turn left by itself, it is slow but consistent, if I let it turn for awhile, it turns back easily with no noise or excessive resistance, if I keep at least 1 hand on the wheel it isn't enough force to rotate the wheel.
but why is it turning by its self while at a complete stop?
thoughts?
Linkback: https://forum.e-bodies.org/wheels-tires-brakes-suspension-and-steering/12/71-340-cuda-w-powersteering/8430/
Offline 73_Cuda_4_Me
  • Trade Count: (0)
  • Big Block
  • Credits: 2120
    • Share Post
Re: 71 340 cuda w powersteering
« Reply #1 on: September 14, 2018, 08:43:56 AM »
Power steering valve (on top of steering box) is out of adjustment, and will need to be CAREFULLY adjusted to center the valve...
https://forum.e-bodies.org/wheels-tires-brakes-suspension-and-steering/12/power-steering-valve-body-installation/8420/msg116192#msg116192
BS23H3B
Offline culp71
  • Trade Count: (1)
  • Small Block
  • Credits: 1140
    • Share Post
« Reply #2 on: September 18, 2018, 11:57:11 AM »
ok, so essentially the placement of the valve body on the steering box housing (side to side) will dictate flow and either center, or cause wheel to move one way or the other. so if I read this correctly, simply I need to loosen the valve body bolts, minimally shift it until the wheel doesn't move then tighten down, right?
  • Trade Count: (0)
  • Big Block
  • Credits: 2120
    • Share Post
« Reply #3 on: September 18, 2018, 01:59:29 PM »
The placement of the valve body (front to rear, not side to side) determines centering... you loosen bolts, but NOT all the way (maybe 10 ft/lbs?), then tap valve body LIGHTLY to the front or rear... scribe a mark where it's at for reference before you start! It does not take much movement, either! Tighten up before starting engine, and keep arms clear of steering wheel!
Read factory service manual, if you have one, and follow all safety procedures, especially safety glasses! Hydraulics is nothing to mess with lightly. I've watched a co-workers hand get shredded by hydraulic oil under pressure, and it was subsequently amputated to save his arm...
While I would adjust sector shaft, I would leave valve adjustment to a professional... my  :alan2cents:
Online Morty426
  • Trade Count: (1)
  • Big Block
  • Credits: 2200
    • Share Post
« Reply #4 on: September 18, 2018, 02:44:50 PM »
Pretty much
Offline Rich G.
  • Trade Count: (1)
  • Big Block
  • Credits: 1100
    • Share Post
« Reply #5 on: September 18, 2018, 06:24:29 PM »
And never stick your hand through the steering wheel and start the car after you’ve replaced or worked on the box. I found that out the hard way!
Offline 71-440
  • Trade Count: (0)
  • Big Block
  • Credits: 2650
    • Share Post
« Reply #6 on: September 18, 2018, 07:01:02 PM »
Wow! Never knew that. I love this site.... :banana:
Joe
 19481820865_95c77794eb_b in 71 340 cuda w powersteering in Wheels, Tires, Brakes, Suspension & Steering
xx
powersteering fluid type
Started by culp71
Last post May 30, 2018, 02:12:59 PM
by BIGSHCLUNK
xx
powersteering hose connecting into rear of pump
Started by culp71
Last post May 15, 2018, 10:22:06 AM
by culp71
clip
1973 Plymouth Cuda Project Car- Real 4sp Cuda
Started by Jakesgeneral
Last post July 17, 2017, 06:40:34 AM
by anlauto
xx
"70 Cuda Go Wing install on a '74 Cuda deck lid
Started by Mopsquad
Last post January 11, 2018, 02:30:09 AM
by HEMICUDA
xx
Not "New" News- But A New Article - 1971 Hemi Cuda Survivor - "Cornfield Cuda"
Started by ScottSmith_Harms
Last post May 06, 2018, 02:06:29 AM
by ledphoot
