avatar_Cudajason
Brake Line Routing?
Started by Cudajason, August 22, 2022, 12:44:10 PM
Ok, this may be a dumb question but here goes,  typically on mopar does the front brake line run from the front or rear of the MC????
Which is the bigger reservoir ? A simple way to remember it is that front disc brakes take more fluid than rear drum so they require a larger reservoir.....If you come across an original master cylinder that has equal size reservoirs, then it was originally designed for four wheel drum brakes :alan2cents:
So front brake line goes to larger end of the master :brainiac:
Quote from: anlauto on August 22, 2022, 12:50:52 PM
Thanks @anlauto
I have one of the newer style Mopar MCs and they appear to be equal size reservoirs.
When I hooked up the new lines to the adjustable dist valve I used the back port for the front brakes. I swear I read that in the factory service manual.
I just went to install a new wilwood MC and they say to run the front brakes to the front port, whis is the larger reservoir. Now it looks like I am bending new break lines again.
Oh..okay...I don't know much about those new style fandangle things....sorry, hopefully someone else will chime in  :waving:
no worries man.
I will follow the Wilwood instructions either way.
