Lesson of the day
Started by GrandpaKevin, August 30, 2017, 04:44:27 PM
GrandpaKevin
When buying new wheels, especially wheels from overseas, make sure you follow the label posted below.
I found out the hard way.
About 2 years ago I bought 2 Weld Pro Star knock offs from the clearance section at Summit Racing, wonder why they were there....
Both marked 15x4" with 5x4 1/2" bolt pattern.
Tossed them in the corner for later use.
Today I mounted new skinny tires then went to install them.
One fit perfectly the other did not.
Turns out the bolt pattern on one is somewhere between 5x4 1/2" and 5 x 4 3/4" :thumbdown:
I've never had this issue with original Weld wheels.
Thankfully the knockoff wheels were cheap, but still a pain to have to buy another wheel, I definitely will be test fitting new wheels from now on.
Well that rots! I'd try Summit and see what they will do. Squeaky wheel gets the grease!
GrandpaKevin
Wheels were purchased 2 years ago and strict no return policy on items from the clearance section makes it not worth the hassle.
The shiny new wheel looks cool hanging on the wall though....
Maybe  make a cool hose reel?  :dunno:
Quote from: Brads70 on August 30, 2017, 06:32:52 PM
Or a base for a coffee table?
6bblgt
is it a mislabeled bolt-circle or a mis-manufactured part?
if the manufacturing was defective, SUMMIT should still honor a warranty
Never hurts to try , obviously you did not screw up the pattern
