avatar_nsmall
Lower steering column
Started by nsmall, July 22, 2017, 09:59:46 AM
It's designed to move up and down inside the coupler.... so clamp it on.  So once it's installed on the gear box you will just need to move it up or down so it aligns with the pin.  It really does not matter where it is right now.  It will be moved to the perfect spot when you install it.   :bigthumb:
nsmall
Thanks Cody.
It's packed full of grease so I'm assuming it's lubed plenty.
Sometimes hard to get the housing over and clamp the pegs over.
Try this.
dave73
Quote from: Roadman on July 22, 2017, 05:49:28 PM
Quote from: 1 Wild R/T on July 22, 2017, 05:46:22 PM
Try this...
http://www.cuda-challenger.com/cc/index.php?topic=91398.0
                  :iagree:   That bearing mod is the only way to go.   :alan2cents:
Yup I did the same, worked great. Bought it on ebay for cheap as dirt.
The coupler was probably one of the most frustrating parts of my front end rehab. I just couldn't get the clips to stay on. Stick with it, you'll get it!
The shoes are designed to float inside the coupler so it doesn't matter where it is now , it will find the right place once it is installed , the nice part about doing the work yourself is now you have the knowledge to help others
