avatar_THE ZUKE
QUESTIONS ABOUT GEOMETRY AND KIT SUSPENSION?
Started by THE ZUKE, February 24, 2019, 07:11:10 AM
THE ZUKE
Quote from: RUNCHARGER on February 24, 2019, 09:16:18 AM
Another upgrade we like to do is to use Tie rod ends and adjusting sleeves from a 1969 Chrysler. They are larger than the Barracuda ones but fit the same.
@RUNCHARGER, you told me "They are larger than the Barracuda ones but fit the same".
Could you explain me because I ask myself some questions about this.
They are larger but fit the same, how is it possible ?
THE ZUKE
@RUNCHARGER and @Chryco Psycho, these questions before ordering the good pièces. ;)
Thanks to you for your answers.  :bigthumb:
Ah yes: My wording was confusing. The swivel ball is larger and the adjusting sleeve and threaded adjusters are larger diameters. The studs which fit into the steering knuckles (lower balljoints really) are the stock Barracuda size. So the tie rod is more robust but will fit in the stock Barracuda location.
THE ZUKE
Quote from: RUNCHARGER on March 02, 2019, 12:56:27 PM
Ok @RUNCHARGER , I understand better than previously but that means that I should change the PST sleeves.
Because the threaded rods will be bigger or not?
I don't know the original ribs because I don't have the original sleeves of the cuda but a PST model.
On a photograph I noted the coast I climbed to the caliper.
Is this the original coast or is tie rods end bigger than those of origins?
I do not know at all...
THE ZUKE
#19
I found this link about my tie rod sleeves : https://p-s-t.com/i-23157806-11-16-solid-steel-adjustable-tie-rod-sleeve.html
My car has this model but I don't know which tie rod end model I need (about axis).
Quote from: THE ZUKE on March 02, 2019, 02:29:30 PM
If I understand your question? You don't necessarily " need" the larger C-Body 11/16 tie rods but a lot of people use them, myself included. Neil quoted you the C-Body part numbers if you wish to use them. They will work with the PST part you linked to.
Quote from: Chryco Psycho on February 25, 2019, 01:40:07 PM
Es355RL & ES352R
are the tie rods that will fit & are heavier duty
This is the part# for the sleeve  10510049
THE ZUKE
#21
Quote from: Brads70 on March 02, 2019, 05:11:26 PM
Es355RL & ES352R
Ok thanks @Brads70 for explanations.
You confirm that on my Cuda, the diameter of the threaded portion of the tie rod end that is screwed into the sleeve is larger than that of an original model.
By changing the tie rods end, should I order 2 pieces Es355RL & 2 other pieces ES352R. One ES355RL and one ES352R for the right side and the same for the left side
Quote from: THE ZUKE on March 03, 2019, 01:56:58 AM
Es355RL & ES352R
Yes the original thread size I believe was 5/8" , yes you will need 2 of each as they are inner and outer  tie rods plus 2 adjuster sleeves.
THE ZUKE
Quote from: Brads70 on March 03, 2019, 05:49:19 AM
Es355RL & ES352R
Ok @Brads70, it's going back slowly in my little head  :)
I have to change 2 pièces like the picture, but what is the name in Américan language ? Upper ball joint or an other name ? What MOOG model I have to buy ?
Thanks for the answer.  ;)
The Upper ball joint you have marked & circled is the idler arm
IMO, if the adjuster sleeves you have (P-S-T) fit the smaller diameter tie rod ends, I would not buy the larger diameter tie rod ends. The difference in driving is not noticeable and the sleeve you have is better than original.
THE ZUKE
Quote from: dodj on March 03, 2019, 06:51:53 AM
Now I have understood that the sleeve adjusters are larger diameter than the original. I have to order the parts (Tie rod end) indicated by @Chryco Psycho.
But I also have to change the both idler arm. I think they are the original model. I am going to look for the MOOG reference.
THE ZUKE
Quote from: Chryco Psycho on March 03, 2019, 06:51:28 AM
Thanks Chryco Psycho.  :worship:
THE ZUKE
Could you confirm me, this link : https://www.summitracing.com/int/parts/mog-k7041/overview/year/1970/make/plymouth/model/cuda is the good piece I need ? Idler arms for my Cuda 1970.
Thanks for the answers.  :bigthumb:
Quote from: THE ZUKE on March 03, 2019, 07:26:27 AM
Yes that is the correct Idler arm the other one on the steering box is called the pitman arm .
