avatar_Roadman
Quiet vacuum pump for big cam motors with power brakes.
Started by Roadman, February 12, 2017, 02:45:32 PM
Interesting, didn't know Hydroboost can pump out up to 2600psi.
Good to know.
chal340
Quote from: 61K T/A on February 18, 2017, 08:03:57 AM
The Hydroboost unit loves pressure *(up tp 2600psi). If your running both power steering and brakes and a low pressure pump you will not have any advantage from a HB system. The maximum benefit from the unit would be running a pump rated for 1350psi. Any higher and you will blow your seals. The pressure drop from the prop valve to the rear brakes is significant. So if your running low a pressure pump you might as well stick with a vacuum booster.  :alan2cents:
@61K T/A.
I read that maximum pressure for a 1.06 Federal pump was 950-1050.
How it's possible to increase this pressure, put a small pulley or change the pressure relief spring?
70 Dodge Challenger 340 A66.
